Results 1 to 14 of 14
    Reputation: ssif21's Avatar
    Sep 2005
    How Often Do You Replace Your Bottom Bracket?
    Mine is five years old but only has about two years of riding (I was off the bike for three years due to medical problems). I did the remove-the-chain-and-spin-the-crank thing. Perfectly smooth. Any reason to replace it? Thanks.
    I yam what I yam and dats all dat I yam
    Every little counts...
    Reputation: Spunout's Avatar
    Aug 2002
    No....
    Paranoid Android
    Reputation: Anti-gravity's Avatar
    Jul 2004
    Quote Originally Posted by ssif21
    There's really no periodic time period for BB replacement. You run em till they die. If the bearings are smooth without any perceptable play, then they are fine. When things eventually get contaminated (if they ever do), then you'll notice roughness, crunchiness or significant play in the bearings. The BB is, of course a self-contained unit, so you can run it into the ground before replacing it. Ride and be happy!
    Sep 2005
    Quote Originally Posted by Anti-gravity
    If I hear crunching the hard part will be figuring out whether it's my bottom bracket or my artificial knee! That thing pops like Chinese New Year.
    To keep my mind occupied during a ride, I tried to calculate how many rotations the bottom bracket makes in a year. For me--limited by weather and work to about 9 months of the year and about 7 to 8 hours a week of seat time--I figured it's 1-3 million rotations per year. Pretty amazing for a $50 part.
    Paranoid Android
    Jul 2004
    There are some people on this board that have gotten many 10s of thousands of miles on a single BB. Kerry Irons has gone through a few, getting as much as 70,000 on one IIRC. I think one was a cup and cone as well. AFAIK, he's pretty good about his maintenance!
    Yet another maintenance-free component, for me
    I'll be the first to say I'm not as picky as I probably should be about maintenance, but in 30+ years of riding, about 20 of them semi-serious, I think I've serviced one or possibly two bottom brackets. It was a while ago, too, because both were old-school cup-and-cone style (now obsolete because, I guess, they were durable, cheap and easy to take care of). I'll probably tear down a couple this winter just because I've decided to go through all the bikes I ride a lot and make sure everything's right, but I don't see any signs of trouble.
    For what it's worth, the BB in my singlespeed--a mid-'80s Trek I rode for years as my main bike, then converted with a BMX freewheel--has been lubed and adjusted once, after I bought the bike in 1994 from a guy who'd ridden it from Indiana to Reno, and it didn't need it then.
    Nasty, brutish, and tall.
    Reputation: SDizzle's Avatar
    May 2004
    Never. Unless you have one of the new, disposable generation...
    I have 50-60k miles on a cup-n-cone Shimano 600, 30-40k on cup-n-cone Shimano Dura-Ace 7700, at least 45k on a Campy Chorus, and 5k mtb miles on a splined Shimano XT that's seen nothing but rigid singlespeed abuse. All are in great shape, except the XT, which is still far from being on its last legs.
    "I've courted brain damage like some courtesan of darkness."
    -The Good Doctor
    Feb 2002
    Replacement vs. maintenance
    As others have said, if the unit turns smoothly without play, then there is no reason to replace it. And even if it has problems, continuing to ride it does no harm other than perhaps wasting a tiny bit of your pedalling effort. However, lots of people have gotten themselves into trouble by only checking to see if things turn smoothly. On some sort of regular basis, the BB should be removed from the frame, all frame and BB threads cleaned and greased, and then reassembleld. If you don't do this, you may find that when the unit does need to be replaced, you can't get it out of the frame because the threads have seized.
    Oct 2002
    Quote Originally Posted by Kerry Irons
    Not to highjack thread, but how many miles/often would the regular removal/clean/relube be done?
    Feb 2002
    Frequency
    Quote Originally Posted by Toothpick
    Hard to say, since riding conditions can vary widely. I do it annually, but that is after several thousand miles, perhaps 4-5 seasons compared to many riders' annual mileage. My gut feel is at least every other year or annually if you do more than 5K miles per year. Experience will tell you whether you need to do it more often.
    Feb 2013
    Bottom brackets should be removed, cleaned, and threads re-greased on a time interval (annual) because grease degrades regardless of usage. Also, old grease will allow seals to dry and rot. If you ride a lot, then it should be done by mileage because dirt can work its way in. There are dust seals between the bearing and the crank arm, they should be removed, cleaned, and re-greased. Failure to do so will allow dirt and water to enter the sealed bearing sooner (learned this the hard way). That grease will create a protective barrier.
    Reputation: crossracer's Avatar
    Jun 2004
    Yea, my experience is that not much grease is used on assembly of the bike, so five years, riding be darned, needs a good removal, clean, grease, and reinstall.
    Glad you are back riding
    'brifter' is a lame word.
    Quote Originally Posted by larsct View Post
    i have to ask...how on earth did you find this (over 7 year old) thread, and why did you feel the need to reply? good advice, though.
    I work for some bike racers
    and a bunch of skateboards
    Velocipediologist
    Reputation: metoou2's Avatar
    Mar 2009
    It seems 'thread dredge' is becoming a past time for more than a few members.
    Creaky has done it for quite some time.
    I will hunt up a thread doing research, but hunting up a thread to then make a reply, mmmmmmmmm I dunno?
