Results 1 to 11 of 11
    Reputation: Lelandjt's Avatar
    Sep 2008
    Impressed with Planet X Brakes
    I was already stoked with the weight (200g for set) and price ($100) but after receiving them I was even more impressed. At this price lots of detailled machining with alloy & Ti hardware are pretty nice but they also came with 3 lengths of alloy caliper stud nuts, an extra cable anchor, tools, and Swiss Stop pads in nicely machined holders!
    Going from dual pivot Ultegras to these single pivot brakes I was anticipating worse power and feel and more difficult setup. They have a clever Servo-Wave type gizmo and gave me the short lever throw I want with decent rim clearance (same as Ultegras) and plenty of power. Not as much power as the 2013 Ultegras I just tried but on par with my 1998s. Setup and centering were easy and the quick release works fine even with my tight, short throw setup. The only downside is centering adjustments require a 13mm open end wrench instead of the more common 3mm allen Shimano and Sram use. Said adjustments are equally fast and easy though.
    2 BIG thumbs up!
    'brifter' is a lame word.
    they are pretty cool looking and are definitely a great deal. no on really ever uses the 'centering' bolt on SRAM or Shimano to center the brakes, but grabbing a 13mm when you set these up is no big deal. they should stay pretty well adjusted. having color options is nice, too.
    2012 Trek Cronus Ultimate w/ SRAM Red Black
    2010 Cervelo T1 sprint bike
    2011 Cervelo P2 pursuit bike
    FMF 24" cruiser
    Bianchi Pista road fixed gear
    1949 Columbia 26" cruiser w/ SRM & fenders...and rust
    '05 Suzuki DRZ400SM
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Does anyone really even use the wrench flats? Regardless of any system's instructions, isn't SOP pretty much to loosen the fixing nut, grab a handful of brake, and tighten the fixing nut?
    A good habit is as hard to break as a bad one..
    Quote Originally Posted by danl1 View Post
    on single pivot brakes, yes.
    FMF 24" cruiser
    '05 Suzuki DRZ400SM
    LC
    LC is offline
    I got both the CNC and slightly heavier (+35g) forged sets. They both function the same but the CNC do look better.
    This was my first experience with Swiss Stop pads and they don't stop as well as Kool Stop Salmon but the harder compound will probably last longer.
    Sep 2008
    I like a short lever throw which necessitates slim pad clearance which requires perfect centering. I use the 3mm allen bolt on normal brakes and when setting these up I used a 13mm wrench to position the caliper while tightening the nut. They have a heavily serrated Ti washer and I could get plenty of torque on the fixing nut so I expect them to stay put. After my morning ride they look the same as in the workstand so all is good.
    There were a couple big braking situations and I forgot I had new brakes, they felt the same as my Ultegras. I swapped my fairly fresh Ultegra pads over and will sell the Swiss Stops as new since I'll need to get carbon pads soon.
    I smoked my previous KOMs and averaged 26.8mph on a hilly 10.5mi stretch so I'll credit that entirely to the 140 gram weight loss
    Quote Originally Posted by Lelandjt View Post
    wait a minute...run that 'average' by me again...MPH? really? who are you signing w/ for next season?
    FMF 24" cruiser
    '05 Suzuki DRZ400SM
    Nov 2009
    by hilly he meant "down" hilly
    Sep 2008
    I've raced pro MTB for a decade. Next year I'll be focusing on Enduro but I'll do a few XC, DH, and road races. Depending on the venue I race for a Culture Of Speed, Avalanche Sports, or West Maui Cycles. This off-season I'm shuffling my suspension and other sponsors. Here's the segment I went hard on this morning: Strava Segment | WMCycles to Honolua Bay
    If you like average speeds I was able to hold 29.6 for this 2.5mi flatish section: Strava Segment | WMC to K
    I was expecting you guys to criticize the short distance, not congratulate on the speed. I wanted to do a quick fast ride, then go surfing. But really, it was the light brakes that made all the difference. Maybe Planet X should sponsor me
    Dec 2009
    I have ridden those roads a few times and they are pretty flat and a strong tail wind (or head wind or cross wind) is possible. Still those are impressive speeds on par with a friend of mine at work who isn't pro and does double centuries in 10 hours.
    Mar 2012
    I have a set in the awesome gunmetal color that I need to put on my CAAD10. I am running some TRP 920sl brakes right now which are great but I will drop 60g total. I really like the look of the CNC brakes.
