Results 1 to 12 of 12
    Apr 2002
    Installed new cables - can't engage all gears now
    I changed out the cables on my bike and shifting is not quite the same now. I can't get the small cog to engage whether I am using the 50 or 34 chainring. To install the cable, I had the largest chainring and smallest cog engaged and pulled the cable until taut and tightened the cable in place.
    Also, when I shift to the large cog in the back, there is some rubbing between the chain and the spokes. I have adjusted cable tension and the cable seems loose enough when try to shift from the 13 to the 12 cog but still it won't move over to the 12. If I adjust more to loosen the cable, it won't shift the smaller to larger cogs.
    I don't want to mess with the limit screws - it worked before the cables were changed so that isn't the solution. Any ideas as to what is wrong?
    Thanks in advance!
    Jan 2009
    Quote Originally Posted by dasho View Post
    Thanks in advance!
    OK a few things are wrong, some were always wrong but you didn't notice, and the other might be you.
    First of all, you might have put too much tension on the cable when you set it up. If there's room to tighten (shorten) the threaded trim adjuster use that to slacken the cable, until everything is OK. My favorite place to set the trim is on the 2nd smallest sprocket, adjusting cable length until shifting between it and high is smooth and crisp in both directions.
    If you can't get this to work it brings up the second and more serious issue, which is the limit screw settings.
    Your inner limit is definitely wrong since you can overshift into the spokes. Shift into high gear, or as close as possible, then shift into low, not with the lever, but by pulling the bare wire away from the downtube like a bow string. Tighten the inner limit until you can shift to low this way, but no further. Later you might fine tune this setting slightly if you have trouble shifting to low by the lever.
    Now, go and see if it shifts to high properly. If not, odds are the high limit is too far in, back it off by quarter turns, keeping track, and see if that solves it. (It's best to push in on the RD slightly to take the load off the screw while adjusting).
    OK, if it turns out both limits were off, it had nothing to do with your cable replacement, but does indicate a third problem. Your hanger is bent inward slightly, probably from dropping the bike. That moved the RD inward, throwing both limits off to the inside. You've now compensated, but at some point might want to have that corrected especially if the shifting isn't crisp and smooth.
    You're actually lucky that you elected to replace the wire at this moment, otherwise you might not have noticed the inner limit/bent hanger problem, and could have shifted into the spokes causing expensive damage.
    For future reference, you might want to do an inner limit safety check from time to time, especially after a crash, using the bow string method.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Apr 2002
    It looks like you are correct about the bent rear der concept.
    I tried playing with the cable barrell adjuster but no luck. So I gently pulled outwards on the the der arm (cage?) and it now shifts to all cogs!
    I am going on a 30 miler tomorrow and see how it acts under a load but I rode a little tonight and it worked fine so I'm cautiously optomistic.
    Thanks a bunch!
    Jan 2009
    Thanks a bunch!
    Next time you want to pull out the hanger, don't pull on the RD itself. Stick a 6mm key in the mounting bolt and use that to bend the hanger.
    Also before you go on that ride, make sure the inner limit screw is set so that the RD cannot overshift beyond the low gear sprocket. Set it based on pulling the wire directly, not the lever because often the last click hides the fact that the RD could move farther, if the cable were pulled more.
    fb
    www.chain-l.com
    Oct 2008
    Sounds like your cable is too tight, probably because the shifter was in the wrong gear when you connected the cable. Disconnect the cable at the derailleur, and spin the pedals. It should automatically go into the smallest cog, if not, then you need to adjust the limit screw. Then push on the derailleur body all the way towards the spokes, you should be able to shift into the largest cog without going over. If it goes too far, or not far enough, you need to adjust your limit screw.
    Once limits are set, use the shift lever to shift into the highest gear, and pull the cable taut, to remove the slack, and reconnect to the derailleur. From here, you should be fairly close, and can use the barrel adjusters to fine tune it.
    Jason
    Feb 2005
    You might also have the washer with the retaining pin oriented in the wrong direction. If not installed correctly, it will hit the derailler cage and not go into the smallest cog.
    Apr 2002
    More good advice - thanks!
    Apr 2002
    For reference sake, can you explain more thoroughly - I don't quite understand where the washer is - thanks!
    Reputation: Mahatma Kane's Avatar
    Oct 2005
    What steelbikerider is referring to is the little washer with a tab under the rear derailleur cable fixing bolt, this tab has to be in the correct position when you tighten down the cable or it will hit the derailleur cage and cause the exact problem you are describing.
    Perception is 9/10 of the law.
    Mehpic
    Reputation: 2cflyr's Avatar
    Apr 2002
    a bit of advice: learn what the limit screws do. it'll make life easy and they're not too complicated.
    catzilla: I wish we were all a little more invincible.
    The NEGU Foundation: Caring for Courageous Kids http://www.thenegufoundation.org/
    Apr 2002
    OK, now I understand - but would that cause the chain to hit the spokes also?
    Mehpic
    Apr 2002
    one guess: limit screws. if they're adjusted properly, it's pretty hard to throw the chain into the spokes with the shifter.
  1. How do I make my brake pads engage evenly??
    By fastfed in forum General Cycling Discussion
    Last Post: 02-27-2011, 07:02 PM
  2. Fall photo thread: Engage!
    By PlasticMotif in forum The Lounge
    Last Post: 12-13-2010, 06:41 AM
  3. Rear hub doesn't engage.
    By RoadLoad in forum Components, Wrenching
    Last Post: 02-27-2008, 04:59 PM
  4. Gear Failing to engage
    By gnarSKYLER in forum Components, Wrenching
    Last Post: 10-04-2007, 06:16 PM
  5. Veloche cassette won't engage
    By Joop Zoetemelk in forum Components, Wrenching
    Last Post: 06-13-2007, 06:49 PM
