installing rim tape
I recently procured a new wheelset but they dont have any rim tape. What type of rim tape should I look for? Is there any special way to put it on or is it as obvious as it seems? Also, they are Velocity A23 rims which I assume means the rim width is 23mm. Do I need 23m rim tape?
Velox. Start at the valve hole, wrap it around, cut off excess if necessary. Don't try to stretch it; just wrap it in place without slack or unnecessary tension..
Get the right width. Measure the width of the center channel on your rims.
Velo plugs
You might consider Velo Plugs as an alternative. We swapped out the Velox and have never regretted it.
+1 on the Velox cloth tape.
here we go...lots of different opinions. velox is great, but it's thick. it you have a tight rim/tire combo, it will make it worse. velo plugs are great...but i never use them. my go-to rim strips for the last few years have been the ritchey snap-on...they are thin, durable, and easy to install. cheap, too...generally less than 2 rolls of velox.
I work for some bike racers
and a bunch of skateboards
Four wheels move your body, two wheels move your soul.
I am happy with velo plugs too. Other than that, all I've ever used is the generic tape that came with whatever wheels I've used, and never a problem. But if I needed to actually buy something, I'd get the plugs again.
Long-time Velox user here, but used Newbaum's ("American Velox") recently and liked it.
Cotton Bar Tape from Newbaum's: Rim Tape
Remember it's mind over matter
if you don't mind it doesn't matter
Ride more drive less
+2 on velox. It's the gold standard.
Judging from the feel and looks of it, Newbaum's may have got it beat. But I'll have to wait and see how it holds up under pressure. Velox has never let me down, no matter how old.
I pull mine tight. For me, doing that pulls the tape into the channel of the rim, so it sits nicely. Granted, I might be using a slightly wider tape than necessary. Had to do a wheel recently because the factory did a crappy job of installing on my new bike.
I have a single track mind
Vittoria Rim Strips
Basically the same thing as the ritchey snap-on... thin, durable, and easy to install.
With the A23 rim you'll want a 21mm tape no matter which brand. Velox and Ritchey are both excellent. I'm using Velox 21mm on my Ardennes which has a 23mm wide rim.
I use Velox rim tape on all of my wheels but it's not good to use if you ride in a lot of water. Cotton rim tape soaks up water and drys very slowly possibly causing rust or corrosion on wheel components.
Whatever your shop has. It is a rim strip, the differences are minute
Will Stans yellow tape do the job?
It is thin, light, or do you have bad experiences with yellow tape and inner tubes?
 Originally Posted by QuattroCreep
Vittoria Rim Strips
I've had problems with these squirming and letting the tube contact the spoke hole. Instant flats for no good reason. They were too narrow for my rims - and these were narrow rims. They'd be even worse for an A23 rim.
If they make them in wider sizes, may be OK. I just got a HED C2 wheel that came with an FSA rim strip. I thought 'oh, great,' but it seems to be wide enough and doesn't want to move around.
Just he same, I'll be getting velo plugs for it the next time I order stuff.
A good habit is as hard to break as a bad one..
By spookyload in forum Racing, Training, Nutrition, Triathlons
Last Post: 09-30-2011, 11:39 AM
By tarwheel2 in forum Commuting, Touring and Ride Reports
Last Post: 07-19-2010, 07:08 AM
By XR4Ti in forum Wheels and Tires
Last Post: 03-20-2009, 03:20 AM
By OPRFHouse in forum Wheels and Tires
Last Post: 05-12-2007, 04:26 PM
By ringroadwarrior in forum Components, Wrenching
Last Post: 10-15-2005, 05:29 AM
- You may not post replies
- You may not edit your posts
Forum Rules
