Results 1 to 25 of 33
    Apr 2002
    Installing Shifter Housing
    It has been a very long time since I replaced the housing in my road bike. My question is about the loop that goes to the rear derailleur. The frame braze-on will only fit a 4mm housing if I remove the plastic from that end. Is there a housing that is intended for that purpose?
    Thanks
    'brifter' is a lame word.
    Quote Originally Posted by daniell View Post
    Thanks
    Old steel bike? If so there are 'step ferrules' that work for that. Maybe post a photo just so we can be sure. There is no special housing that is smaller than 4mm.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2002
    Yes it is an old steel frame. I will take a photo. Where do I get the step ferrules?
    Both Campy and Shimano used to supply them w/ cable/housing kits but no longer do. You can get em here:
    https://www.universalcycles.com/shop...SABEgKfCvD_BwE
    Or if you've got a LBS that's been around for a while they'll probably give you one.
    Apr 2002
    Thanks
    Something that I don't understand. I checked out your link. The inside diameter is 4mm and the outside diameter is 6mm. How would that solve the problem?
    Apr 2002
    Here is the photo
    Attached Thumbnails Attached Thumbnails Installing Shifter Housing-frame.jpg
    Thanks
    Yeah, the little nose goes into the stop on your frame. The I.D. of the ferrule is 4mm to fit the housing. You don't need to pay any attention to the O.D. for this particular spot but that is standard as well. Both shift and brake housing ferrules have an O.D. of about 5.75mm +/- so they'll fit in any frame. Or shifter that uses ferrules...or brake that uses them...or derailleur that uses them.
    Reputation: JCavilia's Avatar
    Sep 2005
    Thanks
    Slightly confusing terminology. The larger section is 6mm OD; the smaller section is 4mm OD, which matches the INSIDE diameter of the stop on the frame.
    Have you ever been to Electric Ladyland?
    Apr 2002
    Quote Originally Posted by JCavilia View Post
    Thank you
    Can you please elaborate. How do I install the ferrule into the frame braze-on?
    Thank you
    Seriously? You just put the small end into the hole in the stop. From the rear of the frame. While the ferrule is installed on your derailleur housing.
    Apr 2002
    Thanks, I will order it along with the spokes for my wheel build.
    Apr 2002
    That looks like a Nuova Record derailleur.
    I believe you're right! One in that shape is probably worth a pretty penny now.
    Apr 2002
    Will I have a problem? I just measured the opening of the stop. It measured 3.96mm.
    You'll find out soon.
    No, you should have no problems.
    Apr 2002
    Do you think that these would work?
    https://www.sjscycles.co.uk/cables/j...-of-4/?geoc=US
    No. As we've posted repeatedly shift housing is 4mm...you need a ferrule w/ an ID of 4.0mm. Not 5.0mm.
    https://www.universalcycles.com/shop...s.php?id=62560
    Oct 2013
    Also here - Shimano part # Y6Z290030
    If it's a little tight, sand the small dia. end of the ferrule down slightly
    https://www.amazon.com/Shimano-SP40-...Cable+Ferrules
    Nov 2014
    Question arises. What did you do with the old step ferrule that came with the old RD housing? I would have just used that after cleaning it.
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    I would think that most any LBS would have many of those step ferrules in a drawer in their shop.
    Trying to cram the rest of my life into the rest of my life!
    Apr 2002
    Quote Originally Posted by GKSki View Post
    That is a good question. I never used one. I had just forced the housing into the stop.
    a real member's member
    Jul 2016
    $50.00
    Quote Originally Posted by blackfrancois View Post
    $50.00
    That's all?!?
    Just saw some NOS NR rear ders on ebay for between $400-500. Used for as low as $50.00.
    Jul 2016
    That's all?!?
    no need for nos. these works of art are almost bullet proof. like vintage suntour, they are easily overhauled. new shimano wheels ($8) fit nicely and look the part. a little road rash can be polished fairly easily.
    vintage super record, on the other hand, might fetch up to $125 in the summer.
    Obviously not *necessary* but I guess there are guys out there that want it.
  1. Installing Brake cable and housing
    By daniell in forum Components, Wrenching
    Last Post: 08-04-2015, 07:46 AM
  2. Can you use a shifter cable housing as a brake housing?
    By bmwjoe in forum Components, Wrenching
    Last Post: 04-07-2013, 11:42 AM
  3. installing sram shifter derailleur cables
    By rielid in forum Components, Wrenching
    Last Post: 03-27-2013, 03:42 PM
  4. Installing Cable Housing
    By minez01 in forum Components, Wrenching
    Last Post: 09-27-2011, 03:31 PM
  5. Internal Brake Housing...Cable Housing....
    By spepic in forum Components, Wrenching
    Last Post: 07-14-2008, 05:40 PM
