Results 1 to 4 of 4
    Feb 2013
    Integrated Seatpost
    Hi All,
    I have a question re: extending the range of my ISP. Picture attached.
    Would you think it wise to dremmel the existing "slit" a bit further to get the required seat height. Other alternative is to get DeRosa to build me a extended seat post and that is not the "cheapest" option!! However, if should the strength of the seat post be affected, its probably the only solution I have at the minute.. changing the seat for larger rail to top length, i have considered but I would only gain 15mm....
    Thanks for any help!
    Timujin
    Reputation: looigi's Avatar
    Nov 2010
    Going higher than the factory designated limit is not generally a good idea. The bike has been tested at that limit to ensure there is adequate safety margin under the designed-for loads. If you are lightweight (maybe under 165 lb?) a few mm (maybe 6?) might be OK, but you are in uncharted territory and taking additional risk.
    Don't they stock longer posts, or perhaps have a conversion to non-ISP?
    ... 'cuz that's how I roll.
    Feb 2013
    Quote Originally Posted by looigi View Post
    Hey, thanks for the reply.. i weight 79kg...so 174lbs...
    They are quoting me Eur250 for the extension!!!!
    Quote Originally Posted by timujin View Post
    You could also check with one of the places that does carbon repair and see if it's a job they could handle. I'm not sure it would be less than $250 but I would guess a repair place would be cheaper than DeRosa. Calfee is the one that comes to mind but there are a few others.
    Anothing thing to keep in mind with jerryrigging is it could void your warranty.
