Results 1 to 4 of 4
Thread: Jockey Pulleys
    Jockey Pulleys
    Are the Dura Ace 7900 jockey pulleys compatible on my Dura Ace 7700 9 speed? I'm using the 10 speed chain so I believe that they are.
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    Yup, they are.
    Trying to cram the rest of my life into the rest of my life!
    The chain has nothing to do with it as all chains are spaced the same.
    The compatibility has to do with the float of the upper pulley. I'm pretty sure Shimano was consistent between 7700, 7800 and 7900 with that but not sure. 11 speed does not have that float shimano used for 10 speed to definitely don't get those.
    Just check your top pulley to see if it floats.
    Oct 2013
    You also need to look at the rear derailleur cage spacing, where the jockey wheels live. Although chain pitch (distance between links) is the same for all speeds, chain width is different, and this drives jockey wheel cage spacing. And so jockey wheel width, as it will be dictated by cage spacing.
  1. Jockey pulleys for shimano 600
    By rs_herhuth in forum General Cycling Discussion
    Last Post: 01-10-2011, 01:50 PM
  2. Loud jockey pulleys on DA 7900 RD
    By DCE in forum Components, Wrenching
    Last Post: 07-14-2010, 04:13 PM
  3. Jockey Pulleys
    By Stew in forum Components, Wrenching
    Last Post: 04-04-2008, 01:20 PM
  4. need jockey pulleys
    By ciclisto in forum Retro-Classic
    Last Post: 11-21-2007, 05:00 PM
  5. Derrailer jockey pulleys, to lube or not to lube?
    By TACSTS in forum Components, Wrenching
    Last Post: 05-12-2004, 11:54 AM
