Results 1 to 9 of 9
    Jul 2012
    Just purchased M530 pedals - lots of foot movement
    I was tired of walking funny using my road style shoes with Look 396 pedals. Generally I don't walk much but I've seen so many more riders with the recessed SPD style shoes allowing them to be able to walk much more comfortably. So I'm trying the M530 pedal with Diodora Team Racer shoes which have the recessed SPD cleat. Last night I attached the pedals and tried out the shoes. However I noticed a lot of foot movement while clipped in. All screws were tightened properly and the pedals tightened to highest tension for clipping out.
    My question is there supposed to be that much foot movement with these style of pedals and cleats?
    I ride a classic and hang the vintage on the wall.
    Feb 2010
    Yes. I run Looks on my roadie and SPD's on my MTB's....a lot more float on the SPD pedals.
    Dec 2006
    Are you using the SM-SH56 cleat (silver)? It's engraved onto the face of the cleat.
    This cleat is a multi-release cleat and will feel like it has a lot of float.
    If that's what you're using, then try the SM-SH51 cleat (black).
    Look cleats come in three "float flavors": Black (0 degree), Gray (4.5 degree), and Red (9 degree). I believe the Shimano cleats are 8 degrees of float.
    Banned forever.....or not
    Aug 2002
    Try SM-SH70 for "less" float.........(zero float)
    Dogbert.
    I>U
    Dec 2006
    The SM-SH70 cleat is made for the old Shimano road SPD pedal-the pedal Lance won the World Pro Road Race on, in '93 I think. It's not compatible with the SPD off-road pedals. Sure; it works, but release is unreliable.
    I know this because I run these cleats on my road pedals. Using them on my off-road pedals is frustrating.
    Jul 2012
    I'm reading on some ebay items (because I can find info on them faster there) that SM-SH56 cleats have 0 deg of float, the SM-SH51 has 4 deg of float, and SM-SH52 6 deg of float. The only thing I know about my cleat is that they are black and came in the box with the pedals. So I'm going to go home and see which ones I have and report back.
    wim
    wim is online now
    Feb 2005
    Quote Originally Posted by Agent319 View Post
    Since you're just coming off old-style Look pedals, there's a good chance you're mistaking ease of float with amount of float. With old-style Look pedals, there's a lot of frictional resistance to foot rotation. Once you get used to that, changing to a pedal that has much less resistance to foot rotation can make you feel like there's much more float even though there isn't in terms of degrees.
    Dec 2006
    I'd caution you as to using anything but the model 51 or 56 cleats on those pedals. I know it sounds like it shouldn't matter, but those are the only 2 model cleats approved for use with those pedals. It says so in the General Safety Instructions included with the pedals and they are the only 2 cleats listed on the parts list.
    Reputation: looigi's Avatar
    Nov 2010
    FWIW: I prefer a lot of float. I use Look road pedals/cleats with float and also MTB with float. I feel this allows my foot to assume it's natural angle (which differs between seated and standing) rather than be artificially constrained by the pedal/cleat.
    ... 'cuz that's how I roll.
