Page 3 of 3 FirstFirst 123
Results 51 to 73 of 73
  1. #51
    Crank Addict
    Mar 2014
    Quote Originally Posted by Oxtox View Post
    fwiw, Sheldon says to never remove the mfg's lube. see below...
    Factory Lube
    New chains come pre-lubricated with a grease-type lubricant which has been installed at the factory. This is an excellent lubricant, and has been made to permeate all of the internal interstices in the chain. This factory lube is superior to any lube that you can apply after the fact [well, unless...see below -- John Allen].
    Some people make the bad mistake of deliberately removing this superior lubricant. Don't do this!
    The factory lubricant all by itself is usually good for several hundred miles of service if the bike is not ridden in wet or dusty conditions. It is best not to apply any sort of lube to a new chain until it is clearly needed, because any wet lube you can apply will dilute the factory lube.
    No worries, I'm not removing the mfg's lube..
    ___________________________
    2016 Pactimo Brand Ambassador
    www.Crankaddicts.cc
    www.skratchlabs.com
    www.hilltopbicycles.com
    2015 S-Works DSW Allez
    2014 S-Works Shiv TT
    2015 Specialized Venge Pro
    2016 Specialized Fuse Comp
  2. #52
    Forever a Student
    Mar 2014
    No way.
    My lube is better than their lube!
    use a torque wrench
  3. #53
    Apr 2011
    If someone can get the supplier for those superior factory lube to sell some to him, he can get a good chain lube business going. Imagine the marketing line, "Same superior lube the chain factory uses..."
  4. #54
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by bvber View Post
    All I know is that "superior factory lube" is as sticky as flypaper and is also a superior dirt magnet.
  5. #55
    Nov 2002
    Agreed. That stuff is nothing but grease. I strip it off first thing by soaking the chain in mineral spirits.
  6. #56
    Reputation: Oxtox's Avatar
    Aug 2006
    I wipe a new chain with a rag, put a week's worth of rides on it, and then apply my regular lube.
    no issues with dirt accumulation.
  7. #57
    Jul 2008
    Here's the broken link. (Yes, I know it's dirty, it's my fat bike)
  8. #58
    May 2014
    Quote Originally Posted by Blue CheeseHead View Post
    Nice work! Consider it a testament of your superior leg strength.
    Or possibly, you jinxed yourself with your previous remark below:
    After 10's of thousands of miles I have never had my own, or seen another rider, have a quick link fail. I have seen poorly installed friction fit pins fail.
  9. #59
    Dec 2014
    Or he shifted while cranking away up a hill under full power
  10. #60
    Nov 2011
    The OMS helps to clean the dirt out and helps get the oil into all the spots. When it evaporates it leaves a thin film of oil on the parts, which tends to collect less dirt than a thick glob of oil.
    I get better results using a separate cleaner and lube. Spraying with WD-40 cleans well without stripping the chain completely. Then I apply the lube of my choice. I have few, and I don't lose any sleep if they aren't perfectly "compatible".
  11. #61
    Apr 2011
    The rest of the chain looks like it had its share of (ab)use. Perhaps the replacement was overdue?
  12. #62
    Jul 2008
    Only about ~300 miles, mostly off road. The pins had no discernible wear. Once cleaned it looked pretty good.
  13. #63
    May 2014
    That should not happen in 300 miles unless you are a mega-clyde super masher.
  14. #64
    Jul 2008
    It's what happens when 215#'s tries to push a 4" tire through 6-7" of heavy virgin snow. Rookie move on my part. Luckily it was in my back yard, so the walk to the garage was not far.
  15. #65
    Reputation: nhluhr's Avatar
    Sep 2010
    Pretty sure KMC makes the high end Shimano chains.
    To Shimano's design specs, not theirs.
    It is exactly the opposite. KMC only manufactures Shimano's low-end chains. You can see the exact models listed in KMCs own catalog at E-catalogue_Product_KMC Chain - check out page 10.
    There you see all the "Licensed by Shimano" chains they make which include:
    CN-4601
    CN-HG73B
    CN-HG53
    CN-HG71
    CN-HG40
    CN-NX10
  16. #66
    Mar 2018
    My bike has kmc chain, and I ride almost 2000mile. But it is not stretched yet, according to checking by parktool.
  17. #67
    Jun 2004
    I prefer a quick link for chain/drive train cleaning. The new 11 speed KMC quick links say one use only. YBN makes a reusable 11 speed link and it works fine on either Shimano or KMC chains.
    KMC seems to have changed their design for the 11 speed to be similar to a SRAM 10 speed power link that is best serviced with a link tool. I have re-used an 11 speed KMC link with no issues. I did really like the 10 speed KMC links that could be installed and removed with your fingers.
    This
    The KMC 11 spd. chain is, according to KMC, not re-usable and requires a chain tool to install. I found this out while attempting to use on a Shimano 11 spd. Ultegra chain and could not install by hand.
    Thus I was not seeing any advantage over simply using the Shimano replacement pins and a chain tool I already owned.
  18. #68
    Reputation: Srode's Avatar
    Aug 2012
    Quote Originally Posted by Steve B. View Post
    This
    What was the problem? I've installed quite a few and never needed a tool for install, I do to take it apart though. Just put it on the top section of chain and pop the pedal with your hand and it snaps right in place.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
  19. #69
    May 2014
    Quote Originally Posted by shoji.triathlon View Post
    This is very possible. How many miles it takes a chain to wear depends on many different factors like rider weight, rider strength, riding style (whether you're a spinner or a masher), whether you ride only in dry conditions or also in rain and wet roads and dirty dusty conditions, how well you lube you chain, etc., etc.
    So as you can see, the big answer to how long will your chain last is.......it depends.
  20. #70
    Nov 2002
    I've had two KMC quick links break on me. The flange broke off one of the pins.
  21. #71
    May 2014
    Maybe you're just too strong.
  22. #72
    Aug 2013
    KMC Chain Missing Link - fakes?
  23. #73
    Nov 2002
    Did that broken link come with the chain? Was it made in Taiwan or China?
  1. Shimano CN vs. HG 10-speed chains?
    By no msg in forum Components, Wrenching
    Last Post: 10-22-2014, 09:02 AM
  2. Chains, Sram vs. Shimano
    By havanabama in forum Specialized
    Last Post: 09-02-2013, 05:10 AM
  3. Shimano vs KMC chains
    By GDTRFB in forum Components, Wrenching
    Last Post: 08-16-2012, 05:58 AM
  4. shimano cassettes and chains
    By focusyourself in forum Components, Wrenching
    Last Post: 11-12-2010, 01:50 PM
  5. Replies: 1
    Last Post: 03-11-2007, 05:09 PM
