Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: Larger Cassette
  1. #26
    Nov 2012
    I also have to say that I am surprised how long it took someone to suggest that I just gradually build back up to fighting weight before trying to conquer hills of my past. Usually that happens in the first or second response. Progress not perfection right?
  2. #27
    Feb 2012
    34/23T is pretty good tho.....
  3. #28
    Apr 2013
    Quote Originally Posted by mybutthurts View Post
    if you don't want the advice, my suggestion is to ignore it rather than be rude
  4. #29
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by GRAVELBIKE View Post
    Wolftooth RoadLink works well for extending a Shimano road mech's range.
    Absolutely. My shop mechanic was able to fix a friend's Ultegra RD bike with a Wolftooth so it can now handle a 36T cassette. However, it's a mid-cage derailleur. I'm pretty sure it wouldn't work with a short-cage.
    Phew, I apologize for creating a thread that became so heated.
    No problem. It happens a lot around these parts.
    I mostly disagree with this premise. On the contrary. If an easier gear makes it possible for you to ride steeper hills, then you will ride steeper hills rather than staying with flat or rolling terrain. As you get stronger, you may no longer need that larger cog, but it's nice to have it there if/when you need it.
    -- Warren Buffett
  5. #30
    Feb 2012
    I will be treating my LBS mechanic to a four-pack of rootbeer tonight as thanks.
    Rootbeer???? WTF???? Give him cash.
  1. Lengthen chain when switching to a larger cassette?
    By azpeterb in forum Components, Wrenching
    Last Post: 05-19-2015, 07:51 AM
  2. Smaller cassette or larger chainring?
    By Lovinglifetx in forum General Cycling Discussion
    Last Post: 08-27-2013, 11:59 AM
  3. compact crankset v. larger cassette...
    By Steve3667 in forum Components, Wrenching
    Last Post: 01-13-2011, 02:52 PM
  4. Can I go to a larger gear in the cassette?
    By Brone in forum Components, Wrenching
    Last Post: 10-26-2010, 11:05 PM
  5. Going to a larger cassette?
    By Toddm in forum General Cycling Discussion
    Last Post: 01-23-2007, 01:33 PM
