Results 1 to 16 of 16
    Aug 2017
    left and right shifters
    Have a long term left hand injury affecting range of movement, and have real difficulty changing up to the large chain ring. Was wondering whether there were shifters where the large chain ring is operated from the right shifter and the rear gears from the left. Would still like front brake to operate from the right. My gear is a late model Shimano Ultegra 11sp mechanical. The other much more expensive option is to upgrade to electronic.
    I don't think so.
    Another option might be to change gearing so you don't need to shift up front. Or at least cut down on how often it's needed.
    Jan 2010
    Would a downtube shifter be any easier? I'd think most frames could take one.
    If not possible with your left hand, you could still shift with you right hand even with the shifter on the left.
    There's sometimes a buggy.
    One.
    Quote Originally Posted by bikerjulio View Post
    It's not pretty, but you could still shift with you right hand even with the shifter on the left.
    I had thought of that but didn't think most frames do, however now that I think about it there's bar end shifters to consider also. Ultegra 11 speed is pretty 'light touch' so I'm not sure it'll be easier though. But perhaps it will if it creates better ergonomics for working around the injury.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Di2. Should be no problem for you to shift.
    Reputation: velodog's Avatar
    Sep 2007
    If you went with a bar end shifter you could work both shifters with your right hand. Bar end for the front and brake lever for the rear.
    Or you could go with a 1x11 drive train or maybe a sub-compact crank like a 46x30. A 46x30 crank with an 11-23 or 25 cassette could be ridden as a 1x11 with a granny. You'd be cross chaining lrg\lrg more than some would like, but you wouldn't be needing to be front shifting much, except in extreme conditions.
    Too old to ride plastic
    'brifter' is a lame word.
    I built a bike for one of our Para girls that used a standard right shifter, a bar end shifter on the right and a splitter for the brakes on the right lever. She raced the crap outta that bike for 2 years.
    I work for some bike racers
    and a bunch of skateboards
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    The big ring shift with Campy Ergo is made on the inner lever, ergonomically the same as the lever used to go big ring to small on a Shimano. A thumb lever is used to go big ring to small. Maybe that would work better for you.
    I am something of a Luddite as far as bike tech goes, but a friend of mine has arthritis is his hands and is thrilled with electronic shifting.
    Dec 2005
    This isn't exactly minimal range of motion, but different motion - use a bar end shifter (on either side) or use an old fashion mtb thumb shifter in friction mode.
    Oct 2014
    As a devoted Di2 user, that would be my first choice.
    The second option would be to consider the new Ultegra fd-8000 front derailleur. I havn't used one, but from the reviews I've read, the force required to shift is substantially less than the fd-6800.
    Feb 2012
    Pics of the setup? Pleassseeeeeeeee?
    Quote Originally Posted by Keoki View Post
    I don't have any. I checked her FB but it wasn't loading. It was a SRAM Red right shifter and a bar end shifter on the right. As I remember we used the hydro rim brakes so a brake line came out of the lever and went into a splitter then to both brakes. If I can get in touch w/ the rider she might have some photos.
    Feb 2012
    What was on the left side as a place holder? A blank shifter?
    Exactly, she hooked her 'hook' prosthetic around the lever body. Still looking for photos.
    Apr 2011
    Look into e shifters either sram or Shimano.
    Aug 2017
    Thanks for all the help. First thing I'll try is a new Ultegra FD-8000 front derailleur, then if that doesn't solve it I'll glue a rubber block on the outside of the shifter to try and reduce travel. Third option is a TT bar end shifter, though I'm not sure if I'd hit that with my knee when out of the saddle. Final option is Di2 which I'm sure is an acronym for "Di"vorce and the $2k+ NZ dollars quote I've had for the upgrade.
  1. Replies: 8
    Last Post: 02-13-2010, 07:24 AM
  2. 105 Brifter Repair. Left bad right good, can I fix the left?
    By IgottaMiyata in forum Components, Wrenching
    Last Post: 07-15-2009, 06:13 PM
  3. On Your Left! On Your LEFT! ONYERLEFT!
    By nonsleepingjon in forum General Cycling Discussion
    Last Post: 08-03-2007, 05:02 AM
  4. BB left and right cups
    By felt35 in forum Components, Wrenching
    Last Post: 04-24-2006, 05:02 AM
  5. The difference between left and right
    By KenB in forum Politics Only
    Last Post: 12-30-2005, 08:19 PM
