leftover links from new chains.
I've been saving my pieces for years now. So far I've been able to make one regular-length chain from them. Of course, it's not all one color. What do you do with yours?
* posted by Creakybot 2013 all rights reserved.
* not actually waterproof.
I do some blacksmithing, so I save them for pattern welding. But doing it with chain is tough - cool though.
fb
www.chain-l.com
Solving any problem requires understanding the underlying cause
bracelet, and mine's not the same color either
"Those who like it, like it A LOT!"
I put mine in ziplock bags, label them, put them away and forget where I put them.
I made a cassete wear indicator tool out of one (similar to the Rohloff HG-IG-Check), some are on my camelbak for spare links on the trail, others are in a pile on the shelf.
How do you connect all the parts of the chain?
I make key chains out of them... I have them on 3 sets of keys.
I've debated on using old chains in artwork before.. Maybe around a frame or something.
I use them as industrial strength garrotes, for when I need to take down large prey silently.
Don't take anything I say seriously.
DIRT BOY
"Pain is a big fat creature riding on your back. The farther you pedal, the heavier he feels. The harder you push, the tighter he squeezes your chest. The steeper the climb, the deeper he digs his jagged, sharp claws into your muscles." - Scott Martin
Pattern welding - nice!
Very cool!
Built a 30-ton hydraulic forging press last year and have been bitten hard by the damascus bug.
Put Road ID on it...
I made a DIY Squeezer out of mine.
 Originally Posted by terry b
I knew Brad Pitt, and you're no Brad Pitt.
 Originally Posted by Gutfiddle
Boogers are paleo, jelly toast isnt.
Unsafe at Any Speed
Wow - that is an astounding achievement. You deserve the green-wrenching-in-green-transport award.
I use 108 links from a 114 link chain, so have about 6 left over each time, so will make an extra chain every 19 new chains or so.
Of course, it will require 19 Connex links....
I may have used up 19 chains in my life, but no match - they varied from 6-speed through to 8, 9 and 10 speed so no go for me.
I keep my leftovers as wear check references for new chain roller clearance. And I have removed and used a new roller here and there.
Saved the first Campy 11 bit (see keychain). All else, trash.
Our shop has a guy who takes the recycling and trash away. He basically does it for the scrap metal. I put all that stuff in his bin. Of course at $14/100# it would take you a long time to benefit from this.
Ya, what ATP said...!
I connect old chains and scraps together. When they reach about 30 feet, i make a spiral bowl out of the and a friend tack welds them into place. I only ride stainless chains so they shine up nice.
Friend of mine wraps picture frames with old chain for his cyling photos which is pretty cool looking.
can these be recycled at a scrap metal center? (steel)?
Absolutely, and if you have no other use for them that's where they should go. If your city recycles steel cans and jar lids, you can toss them in with that for curbside pickup.
However, don't think you can get anything for recycled non-stainless steel. The going rate is a few cents per pound, and If a recycler has to come to pick it up you'll pay him for the time and fuel used. When I manufactured I could get rid of steel scrap for free, but when they were also there to buy my brass.
fb
www.chain-l.com
They make good little pieces of weight. Useful for throwing at dogs coming at you.
Actually, with your bits, I had them melted down and reformed. You like?
I use them to chew on whenever I have days like this one.
You know that little thing in your head that keeps you from saying things you shouldn't? ......Yeah, I don't have one of those..
- You may not post replies
- You may not edit your posts
Forum Rules
