Results 1 to 3 of 3
    May 2004
    Little problem with new' (NOS) 7-speed HG cassette
    Well, I finally got around to replacing my chain and cassette after 4600 miles. I have Ultegra hubs with the little spacer which is required when using a 7-speed cassette on a 8/9 speed hub. When I tried to install my NOS 7-speed cass, the locknut wouldn't thread on because the cassette was sitting 'too high'. Seems the new cassette's three rivet heads protrude beyond the big cog's surface, much more than my OEM cassette's rivets. The OEM cassette's rivet heads were kinda 'flathead' style, if you know what I mean.
    So my question: should I drill three pockets in the spacer for the rivet heads so the cassette's largest cog sit flush against the spacer? I kinda hate to do this because I think pocket needs to be at least half of the spacer's thikness. If anyone else had this problem and better yet, a solution, I'd surely be grateful to hear your story.
    thanks,
    JT
    Rivets
    Quote Originally Posted by Hobart
    thanks,
    JT
    I've created clearance in the spacer, ground off the rivet(bolt) heads,and even removed them.All seem to work.
    Jan 2002
    Are you sure they are rivets?
    A while back I was changing my 7-speed cassette, and with pliers I unscrewed what I thought were rivets. They were actually screws and I was able to pull them all out. That doesn't mean yours are not rivets, just something to try.
    guidosan
  1. Sora 8 speed shifters with ultegra der. chain and 8speed cassette
    By mxtater9 in forum Components, Wrenching
    Last Post: 06-20-2004, 07:27 AM
  2. what if i want 8sp?
    By colker1 in forum Components, Wrenching
    Last Post: 06-05-2004, 04:22 PM
  3. Where to find NOS 8 speed?
    By daneil in forum Components, Wrenching
    Last Post: 05-10-2004, 09:15 AM
  4. 7 Speed HG Cassette - Work on 8/9 speed freehub
    By Gus8 in forum Components, Wrenching
    Last Post: 05-02-2004, 10:12 PM
  5. Is a 9 speed chain compatible with 8 speed cassette?
    By mdevos in forum Components, Wrenching
    Last Post: 04-15-2004, 11:32 AM
