Results 1 to 2 of 2
    Sep 2010
    LOOK KG486 internal cabling problem..
    Quick question, I recently acquired a Look KG486 frame and Iím having a little issue with the build. The rear brake housing is suppose to run internal through the top tube, but I cant seem to get the standard 5mm brake housing to fit, is there a 4mm brake housing or Iím missing something?
    Sep 2010
    Nevermind... after taking a closer look at the holes there seemed to be some currosion right at the point where the housing goes in to the frame... once I cleaned up the holes the 5mm brake housing went through without any problems.
