Results 1 to 4 of 4
    Reputation: Srode's Avatar
    Aug 2012
    Lube for inside of 6800 shifter?
    I cleaned out the inside of my rear DR 6800 shifter this morning, pretty gunky in there. Just wiped out the gunk with a towel. Any suggestions on what lube to reapply? I have Phil Wood water proof stuff in the green tube, would that be suitable?
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    'brifter' is a lame word.
    I'd want to use something light that won't get too sticky over time. A light teflon grease maybe, or something like 'Shimano Special Grease'. Phil might be a little thick but it stays greasy for a long time which is good.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2012
    thanks, I'll use the Shimano special grease.
    Gravel Rocks
    Trek Domane
    Trek Crockett
    Feb 2002
    FYI there is nothing all that "special" about Shimano's grease. Any quality grease will be fine. If you're willing to do a little more regular maintenance, a heavy oil (like 90w gear lube) will let things operate smoothly with less likelihood of gunking up.
  1. Problem installing 6800 Front Derailleur FD-6800
    By TiCoyote in forum Components, Wrenching
    Last Post: 02-14-2015, 10:44 AM
  2. Chain wrap capacity with 6800 and use of Force 22 crank with 6800
    By nkranhold in forum Components, Wrenching
    Last Post: 02-11-2014, 08:41 AM
  3. Dry lube vs wet lube
    By Export A in forum Components, Wrenching
    Last Post: 07-10-2007, 07:40 AM
  4. Lube- that is, chain lube
    By filtersweep in forum Fixed/Single Speed
    Last Post: 06-03-2005, 04:17 PM
  5. Derrailer jockey pulleys, to lube or not to lube?
    By TACSTS in forum Components, Wrenching
    Last Post: 05-12-2004, 11:54 AM
