Results 1 to 12 of 12
    What the what???
    Jul 2009
    Machining 11sp cassette
    Considering going from 10sp to 11sp. Anybody had any experience with:
    11 speeds cassette compatible with 10 speeds hub – Lasco Concept
    They machine Shimano and SRAM 11sp cassettes to fit on 10sp hubs.
    I get the idea and it makes sense, but can anyone confirm if it works in practice? Any fitment or performance problems?
    The Law of Headwinds states: If the ride out is easy... wait.
    'brifter' is a lame word.
    No reason why it shouldn't work just fine. Never seen one, but it should work.
    I work for some bike racers
    and a bunch of skateboards
    What the what???
    Jul 2009
    Good to know. They're a little spendy but maybe an option for a 10sp hub with a lot of life left in it.
    Banned forever.....or not
    Aug 2002
    Is it a Shimano hub??.What size cassette?
    Dogbert.
    I>U
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Opus51569 View Post
    I guess if it's a high end wheel, it would be worth it.
    Statistics are like bikinis. What they reveal is suggestive, but what they conceal is vital. -- Aaron Levenstein
    Frog Whisperer
    May 2003
    A good friend of mine did one for his son. It worked well. (he is a clock maker by trade)
    Of course I'm sure...that doesn't mean I'm right.....
    "There's no sense being stupid unless you show it."
    "that was like trying to teach a goldfish how to play basketball over the phone."
    Feb 2005
    You need to take 1.85mm off the back of the cassette where it butts up against the freehub. That's what the wheels Manufacturing conversion cassette does. They also have some .3mm spacers to fine tune the spacing. I used a Wheels 11 speed conversion cassette on a Shimano Dura Ace 7850 rear hub and 2 - .3 mm spacers so the wheel would interchange with a DA 9000 wheelset without needing adjustments. It worked great.
    Russian Troll Farmer
    Sep 2016
    My only concern would be if the removal will weaken the cassette too much.
    "L'enfer, c'est les autres"
    Reputation: velodog's Avatar
    Sep 2007
    If there's a machine shop in your area they may be able to do the job.
    Maybe a friend with a lathe.
    Too old to ride plastic
    What the what???
    Jul 2009
    Quote Originally Posted by MR_GRUMPY View Post
    Shimano 105 hub. If I go with the Lasco option, the cassette would probably be their SRAM 11-32 and Id run it as a 1X.
    Sent from my iPad using Tapatalk
    Frog Whisperer
    May 2003
    yes.....he can!
    May 2011
    Or something like....
    https://www.sigmasports.com/item/Edc...tte-11-27/6G97
    Sent from my iPad using Tapatalk Pro
    Well, you know, that's just, like, your opinion man. - The Dude
  1. Replies: 8
    Last Post: 12-04-2015, 12:59 PM
  2. machining a damaged wheel?
    By cisco32 in forum Wheels and Tires
    Last Post: 03-31-2012, 05:23 PM
  3. Replies: 0
    Last Post: 01-06-2010, 06:33 PM
  4. Zanconato Custom Bike #3: Machining Tubes
    By team_sheepshead in forum General Cycling Discussion
    Last Post: 05-13-2006, 07:30 PM
  5. (Re)machining braking surfaces-Sooper grabby
    By Sablotny in forum Wheels and Tires
    Last Post: 05-14-2005, 02:53 PM
