Mavic cassette
I know that mavic makes a conversion cassette that can make a Mavic (shimano compatible) wheels work with a 10speed campy drivetrain. Has anyone ever used it before? How is it?
Also, would this cassette only work with a shimano spline hub? Or i can use it with my campy spline hub as well?
Basically if i have two mavic wheelsets (one shimano compatible, the other campy compatible), will i be able to use this cassette for both wheelsets?
Thanks
Thanks
I have one. A 12-25 10sp. It works on Shimano freehubs and allows you to use a Campy drivetrain. It shifts perfectly! I run it on a 2003 Campy Chorus/Record drivetrain with no problems. It will not fit a Campy hub.
requires a mavic M10 freehub...
This cassette can only be used on a Mavic M10 freehub that has a shimano spline pattern and a casette body that is longer than standard shimano body. It won't work with standard shimano hubs, or other brands of shimano compatible hubs.
It works with American Classic, right?
american classic 10-speed...
The AC 10-speed cassette does fit a standard shimano freehub.
By gobuffs in forum Components, Wrenching
Last Post: 05-08-2012, 09:50 AM
By bikewriter in forum Components, Wrenching
Last Post: 09-07-2004, 10:25 AM
Last Post: 04-06-2004, 07:32 PM
By ianpiston in forum Components, Wrenching
Last Post: 03-23-2004, 12:11 PM
By hayaku in forum Components, Wrenching
Last Post: 02-11-2004, 09:36 PM
- You may not post replies
- You may not edit your posts
Forum Rules
