Results 1 to 4 of 4
    Feb 2005
    Mavic M10 cassette and Shimano hubs
    Has anyone successfully installed a Mavic m10 cassette on a Shimano compatible hub? I tried it on a Bontrager hub put it appears the lockring is too short. Also the wheels manufacturing Shimano/campy 10 cassette does not appear to work with the Bontrager wheel either. Any suggestions would be appreciated.
    Thanks
    won't work..
    The mavic M10 cassette has shimano splines, but it only fits mavic M10 hubs that have a longer cassette body. It's not intended to work on standard length Shimano splined hubs.
    Dec 2004
    [QUOTE=wheel_suker]Has anyone successfully installed a Mavic m10 cassette on a Shimano compatible hub? I tried it on a Bontrager hub put it appears the lockring is too short. Also the wheels manufacturing Shimano/campy 10 cassette does not appear to work with the Bontrager wheel either. Any suggestions would be appreciated.
    C40 is correct - i had a pair of Shamals with shimano freehub body that a mavic cassette would not fit on to. length of freehub body is different and mavic cassette will only fit to mavic wheels. try a different lockring if you can find a long one or try TA or Marchisio conversion cassette or get your LBS to change the freehub body.
    i went as far as to sell the mavic wheels and cassette on ebay (for a good price i might add)
    Feb 2005
    Thanks guys thats what I figured. The Wheels manufacturing conversion cassette did not work either. The first cog hits the spokes. Its a 2004 race x carbon wheel. I got quoted $200 for the conversion kit from a lbs. any idea if this will fit?
    http://store.airbomb.com/ItemDesc.asp?IC=FW1912
  1. Shimano cassette for Campy hub?
    By MEGAWHACKER in forum Components, Wrenching
    Last Post: 08-20-2004, 10:31 PM
  2. Mavic and shimano cassette compability
    By Erik in forum Components, Wrenching
    Last Post: 07-01-2004, 06:02 AM
  3. Cassette Kit for Shimano Hub and Shifters
    By JerryZ in forum Components, Wrenching
    Last Post: 05-30-2004, 06:10 AM
  4. Mavic cassette
    By boat in forum Components, Wrenching
    Last Post: 04-08-2004, 05:34 AM
  5. 8speed Shimano to 10speed Campy cassette
    By hayaku in forum Components, Wrenching
    Last Post: 02-11-2004, 09:36 PM
