Results 1 to 9 of 9
    Reputation: OldZaskar's Avatar
    Jul 2009
    Mechanical 6800 Rotation Adjustment Screw
    When did this show up? Why do some mechanical 6800 braze-on front derailleurs have it, and some don't?
    Jan 2017
    AFAIK all shimano 11sp have this.
    105 5800
    Ultegra 6800
    Dura Ace 9100
    I own and all have it
    Jul 2009
    Well damn. evan326, you're right. I had looked at my 6800, and didn't see it, read your reply... went back to look closer (with my #%$&ing glasses on) and yep - it's there. I've installed three 6800 front derailleurs and missed it each time. That's pretty bad.
    Jan 2017
    Happens to the best of us.
    'brifter' is a lame word.
    RTFM. And you can only see/adjust it in the small ring position.
    I work for some bike racers
    and a bunch of skateboards
    Jul 2009
    You have no idea how right you are... I was helping a friend who'd never installed a derailleur before. He's new to wrenching (not riding) but learning fast. I've been building bikes for 40+ years so, why would I have to read a manual for a simple derailleur install. HE pointed out that screw... 'cause he'd read the manual. Yep. RTFM.
    Oct 2014
    There are other, perhaps better reasons to read the manual for that particular derailleur. Not the least of which is the cable routing at the pin/cinch bolt.
    When set up properly, it's a fine, smooth shifting derailleur. If it's not, it's a hot mess.
    Oct 2011
    And on some bikes that little screw only hits air. Trek Domane 600 comes to mind because of the seat tube shaping. So it cannot always be used.
    Anyway, it is nice when it can be used.
    Don't forget to use the little stick on piece of metal for it to press against.
    Sometimes folks forget to stick that on the frame.
    Quote Originally Posted by OldZaskar View Post
    Don't ya love getting schooled like that? One of our guys that's not a full time mechanic built a bike w/ the new 9100 D/A the other and was raving about how well the new front derailleur shifted. I took a look at it and said 'It's even better when you set it up correctly'...I had him watch the install video and heard him say 'ooooohhhh' at least 3 times!
  1. Adjusting Campagnolo rear derailleur - no B screw or H screw
    By Glyndwr in forum Components, Wrenching
    Last Post: 03-04-2016, 05:42 AM
  2. Problem installing 6800 Front Derailleur FD-6800
    By TiCoyote in forum Components, Wrenching
    Last Post: 02-14-2015, 10:44 AM
  3. Best place to buy Ultegra mechanical 6800
    By Mtldealer in forum Components, Wrenching
    Last Post: 11-20-2014, 02:33 PM
  4. Chain wrap capacity with 6800 and use of Force 22 crank with 6800
    By nkranhold in forum Components, Wrenching
    Last Post: 02-11-2014, 08:41 AM
  5. Derailleurs: Limit Screw and B-Screw adjustments
    By RyKnocks in forum Components, Wrenching
    Last Post: 04-13-2012, 05:41 PM
