Results 1 to 7 of 7
    Rodie Persona
    Reputation: MTBMaven's Avatar
    Dec 2005
    Miche Supertype Post Special?
    Working on parts for my De Salvo steel frame, which is due in 2 months or so. Considering the Miche Supertype post. The post is clearly beautiful (to me at least) and has a unique clamp style. Beyond the clamp style and beauty, is there anything else that makes the post worthy of my consideration?
    What's with the cut outs? Looks? Bump absorption? Weight savings?
    I thought of that while riding my bicycle. ~ Albert Einstein on the theory of relativity
    duh...
    Jan 2005
    Quote Originally Posted by MTBMaven
    bump absorption? surely you jest
    Rodie Persona
    Dec 2005
    Quote Originally Posted by FatTireFred
    Vibration absorption? Come on give me something...I'm trying here. Can it really just be a pretty seatpost for $120? Have I found the only high priced bike part that performs just like the cheaper stuff?
    Oct 2007
    clamp allows tilt adjust without the risk of fore/aft change.
    should be more like $75.
    Rodie Persona
    Dec 2005
    Quote Originally Posted by dookie
    That's pretty slick.
    Thanks found it on Bike Works NYC but only in black. Will have to see if they can get a silver one.
    hello
    Reputation: roadfix's Avatar
    Jun 2006
    Other than the ugly, silly, over-designed saddle rail clamp cluster, it is a finely crafted seatpost. It'll be much nicer if it had a simple single bolt rail clamp instead.
    Otherwise, I like them, I have several in both colors.
    Rodie Persona
    Dec 2005
    Thanks Roadfix. I was hoping you would respond. I knew you had several. I first learned of the seatpost from your fixies. They really are pretty.
    If I go with the Miche I will discuss it over with Mike before he starts working on the geometry as the Miche has a larger set back than say a Thompson, which will affect top tube length and stem choices.
Contest
Tour De France
