I read online that Zinn has had success using a sram rd with Campy ergopower 10 speed shifters. My question is can I use any Campy 10 speed shifters with a Sram rd? I ask because I'm thinking of building up a fowl weather bike like this. Thanks
All Campy 10s shifters and derailleurs have identical pull ratios, so if it works with one, it'll work with all. Otherwise I'm not saying it works, you'll have to take Zinn's word for that, or do whatever he did to make it work.
It's easy to explain why this does not work well. SRAm RD's require a uniform 3mm of cable pull per shift, according to SRAM. Zinn measured it to be 3.1mm, but he also mismeasured the Campy shifter pull.
Campy 10 shifters make nonuniform cable pulls. Those pulls are 2.5mm five times, 3mm twice and 3.5mm twice. After those first five pulls, the RD would be out of position by nearly a full cog.
Campy RD's don't all have the same actuation ratio. Campy made a change in 2001. The 2009+ 11 speed RDs also have a little greater actuation ratio than 10 speed.
As C-40 has pointed out, Campy and SRAM are fundamentally incompatible. You will end up with a kludge, though that is "good enough" for some people.
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
