Picked up a nice Univega Nuovo Sport built up with a 3x9 speed Ultegra drivetrain and 700c wheels. The frame takes 27" wheels, but the long-reach single pivot Tektros that came on it are bad. The rear brake is held in place with a hexagonal nut.
I want to put modern dual-pivots on it, but can't find any that use an exposed nut on the rear. If the rear bolt on the modern brake is long enough, can I just discard the stock recessed "nut" and replace it with an exposed nut?
The bolt won't be long enough to do that, but you can carefully drill out the hole to accept the recessed nut. It doesn't have to be enlarged much.
But you might try just putting on new pads (good ones like Koolstop) and see if you get satisfactory braking performance.
If I understand you correctly, you've got 700c wheels on a frame made for 27", so you'll need a long-reach caliper if you replace. If you do, make sure you measure the required reach before you buy.
If you do this operation gently, with a hand reamer and a little cutting oil, you shouldn't have any problems making the hole big enough for a recessed mounting bolt. But I'd try the brake pad switch first, too.
Or use a long bolt from a front installed on the rear, then use the external nut. Would be easier to just use another front brake.
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
