Results 1 to 12 of 12
    Jul 2002
    Moustache/Cruiser Type Bars That Take STI?
    Does anyone know of any bars similar to the SOMA Sparrow that are compatible with STIs? Thinking of turning my Cross Check into a cruiser/grocery getter for the summer.
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    The only ones I know of are the true Nittos. Too bad they dont come in oversize clamp diameters.
    Jul 2002
    Quote Originally Posted by tihsepa View Post
    Hmmm. May have to go bar ends and levers then.
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    Here's some pictures of a Soma Sparrow with STI mounted:
    surly cross-check after one year | Flickr - Photo Sharing!
    Nov 2008
    Quote Originally Posted by Kontact View Post
    Yah, he mentioned those. They have a tighter bend than the Nittos. I think its s preference though.
    Apr 2011
    Oh, I thought you meant they were the only ones. Any mustache bar should work.
    If you want 31.8, FSA and Civia come to mind. Just do a search for "31.8 mustache handlebar".
    Jul 2002
    Interesting. I really like the Sparrows, but found this in the FAQ section on the SOMA site:
    Sparrow Bar 490/520/560
    What grips/levers are these handlebars compatible with?
    Compatible with MTB grips and shifters (road brake levers, e.g. Shimano STI will not work). The bar ends are designed to fit Soma pursuit levers or bar end shifters, which is recommended since its narrowness prevents it from fitting side-by-side shifters and brake levers unless you trim the grips.
    Fits 3-speed Sturmey Archers great.
    wim
    wim is offline
    Feb 2005
    This Nitto moustache bar would work. While it has a 26.0 mm stem clamp diameter, it does have the 23.8 mm STI shifter clamp diameter you need.
    Nitto Moustache Bar 26.0 - 16028
    Apr 2011
    Quote Originally Posted by lampshade View Post
    It may be a bar diameter issue, but that doesn't mean it can't be fixed with a shim under the lever band clamp.
    wim
    wim is offline
    Feb 2005
    Absolutely. On the other hand, why kludge it if you don't have to? The 26.0 mm bar clamp diameter stems are out there. This one (Leadtec LCS7091) even comes in 17 degrees for that parallel-to-the-ground classic look. Note: Moustache bars put your hands way out there, so you may need a significantly shorter stem than you use with road- or straight flat bars.
    Apr 2011
    Quote Originally Posted by wim View Post
    That's a pretty stem for $22. And I agree - 26.0 or 25.4 stems are not hard to find. Neither are mustache bars.
    Nov 2010
    not exactly a mustache bar, but Salsa has a very comfortable but weird looking drop bar that flares out. I have one on my Fargo. I would not hesitate to use it for the purpose you discribe.
