Results 1 to 7 of 7
    txn
    txn is offline
    Reputation: txn's Avatar
    Apr 2006
    NDS crank arm keeps coming loose
    Ultegra 6500 crankset (Octalink). Iíve been having issues with the NDS bolt backing out as I ride. Iíve retightened and torqued to spec many times. Also, itís done this with two different bottom brackets. Any suggestions on what to do next?
    Aug 2013
    Buy a new nds crank arm or a new crankset. Your crank arm is toast.
    Quick fleabay search results in about $30 for used set.
    'brifter' is a lame word.
    ^This^. If it won't stay tight it's done. Replace it. It was most likely installed by someone that didn't know how to do it by feel properly and was too lazy to remove the cap and confirm it visually.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2002
    Most likely. It should be really easy to see the damage to the splines. If it is not damaged, then thread locker might be the answer, though it shouldn't have to be the answer.
    Russian Troll Farmer
    Sep 2016
    If you resort to using threadlock, make sure it's a mild version. Some threadlock formulas require a torch to remove.
    "L'enfer, c'est les autres"
    Like the one that whoever builds hubs/freehubs for Vision uses? The stupid ass freehub that is failing on probably half of the OEM Metron 40 LTD wheels that requires a torch and a 12mm allen? That threadlock?
    txn
    txn is offline
    Apr 2006
    Thanks for all the replies. Looks like Iíll throw some thread lock on there and start looking for a replacement crankset
  1. Round threaded insert on the crank keeps coming loose
    By Mr645 in forum Components, Wrenching
    Last Post: 12-02-2013, 06:56 AM
  2. how loose is too loose (NDS side)
    By adam_mac84 in forum Wheels and Tires
    Last Post: 07-25-2012, 11:21 AM
  3. Rival crank arm keeps coming loose.
    By bkranich in forum SRAM
    Last Post: 03-12-2008, 05:17 AM
  4. FSA crank keeps coming loose
    By STLRoady in forum Components, Wrenching
    Last Post: 08-27-2006, 01:42 AM
  5. Help! ISIS Crank Bolt Keeps Coming Loose
    By fbagatelleblack in forum Components, Wrenching
    Last Post: 06-04-2006, 06:18 PM
