Results 1 to 7 of 7
    Aug 2009
    Need 1" Carbon Fork w/ Clearance for 28mm Tires
    I'm trying to find a carbon 700c fork with 1" steerer and clearance for 28mm (measured) tires with a little room to spare. Trying to keep the price below $100 at the same time. Nashbar has a carbon 1" fork and I can find some old reviews claiming that they will fit. Can anybody vouch for the clearance on the Nashbar fork or does anybody have any other suggestions that will meet my criteria? Thanks.
    Jan 2010
    No problem.
    I just checked mine with 25 mm tires and have 5 mm each side and more at the top.
    I have the fork on my Merckx and can reccomend it as well.
    There's sometimes a buggy.
    One.
    Aug 2009
    Thanks.
    Jan 2010
    here's a pic of a dusty bike with said fork. That's a 25 mm tire on a wide rim too.
    Need 1" Carbon Fork w/ Clearance for 28mm Tires-img_20170908_211301085.jpg
    One.
    Aug 2009
    Bikerjulio,
    What brand and model of tire and rim are you running? I'm curious if you're on the +/- side of 25mm. Thanks again.
    Jan 2010
    Sorry, too many wheels. That pic is a Michelin Pro4 25 mm on a Neutron, measures 25 mm exactly. With 5 mm each side.
    This is the same tire on a Pacenti SL23, measures 26.3 mm. There's a comfortable 4 mm each side. Plenty of room at the top. That's just the angle.
    So, a true 28 mm should be fine, with over 3 mm each side.
    Need 1" Carbon Fork w/ Clearance for 28mm Tires-img_20170909_095614838-1-.jpg
    One.
    Aug 2009
    Good info. That helps.
  1. Enve 2.0 road fork with 28mm tires
    By jemsurvey in forum Bikes, Frames and Forks
    Last Post: 07-17-2017, 02:14 AM
  2. Replies: 36
    Last Post: 02-15-2016, 09:41 AM
  3. Replies: 23
    Last Post: 04-04-2013, 01:06 PM
  4. 1" Carbon Fork to a 1-1/8" Carbon Fork Conversion?
    By steveh_houston in forum Components, Wrenching
    Last Post: 08-26-2007, 07:04 AM
  5. 27mm or 28mm CX tires w/ Ouzo Pro Fork?
    By Moosedryvr in forum Wheels and Tires
    Last Post: 12-01-2005, 03:17 AM
