Results 1 to 7 of 7
    Jan 2005
    new chain, new grinding?
    My old chain was at .75, so I put a new one on. I seems smooth when the bike is on the stand. When I pedal with load, it seems to have a frequent grind. I am thinking I also need a new cassette. Any other ideas? Sram force 10 speed components.
    Thanks
    Sep 2011
    you need a cassette
    tjc
    tjc is offline
    Aug 2010
    you probably already checked, but make sure the chain is routed correctly through your rear derailleur wheels.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    How badly lubricated (or not at all) are the pulley bushings/bearings?
    'brifter' is a lame word.
    Quote Originally Posted by tjc View Post
    He'd notice that in the stand for sure. Most likely needs a new cassette. Happening in all cogs or the ones you use the most? Notice more in the smaller cogs?
    I work for some bike racers
    and a bunch of skateboards
    Feb 2002
    Quote Originally Posted by deadleg View Post
    Thanks
    If you stand on the pedals and your chain skips on the cassette, that means a new cassette (or at least replace the cogs that skip, which is typically not an option but sometimes is). Not sure what you mean by "grind."
    Right. New chains tend to be a little louder than old ones, for a little while. No mention of bad shifting or anything else here, just "grinding" aka noise. If that's it and it's not 'that' loud or weird/different sounding it's probably nothing out of the ordinary.
  1. Grinding in New Freewheel
    By Duane Behrens in forum Components, Wrenching
    Last Post: 03-23-2014, 01:04 PM
  2. chain grinding front inner cage plate
    By Radix in forum Components, Wrenching
    Last Post: 11-18-2009, 06:41 PM
  3. Chain Grinding....
    By rjb294 in forum Components, Wrenching
    Last Post: 10-28-2005, 05:40 PM
  4. grinding when pedaling
    By shaq-d in forum Components, Wrenching
    Last Post: 05-11-2005, 03:52 PM
  5. grinding in 42/25: normal?
    By fiddledoc in forum Components, Wrenching
    Last Post: 07-06-2004, 04:33 PM
