Results 1 to 7 of 7
    Apr 2002
    New rear der not lining up with cogs.....
    I replaced my 10 speed Shimano DA (short cage) rear derailleur with a new 10 speed 105 medium cage.
    I mounted the 105 but for some reason the derailleur jockey wheel is not aligned with the smallest (12t) cog but about 2 or 3 cogs in. It seems the rear der needs to move outward but how?
    I hooked the shifter cable but figure I'd check here before I waste time or screw up.
    Thanks in advance...
    Forever a Student
    Mar 2014
    Manuals & Tech doc
    Go down to page 25 to start.
    Link takes a while to load the manual.
    use a torque wrench
    'brifter' is a lame word.
    Pretty sure you've discovered that fact that new derailleurs don't come pre-adjusted. You ALWAYS adjust the limit screws before you attach the cable.
    I work for some bike racers
    and a bunch of skateboards
    Not a climber
    Reputation: dcorn's Avatar
    Sep 2011
    artscyclery.com has some good DIY videos on how to set up your drivetrain. Used them to get my odd SRAM Yaw FD dialed in when the LBS couldn't figure it out.
    That or your RD hanger is bent. My CX bike RD hanger came bent from the shop, brand new.
    Quote Originally Posted by dcorn View Post
    If your shop couldn't figure out a YAW derailleur I'd look for a new shop.
    All hangers are straight when new...it's the frame interface that isn't perfect causing you to need to align your hanger to that particular frame.
    Apr 2002
    I think you hit it...
    I didn't realize the limit screw could move the pulleys that far. I will try it when I get home.
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by dasho View Post
    Yep. 3 cogs in sounds like limit screw is turned all the way in.
    Did the bike possibly fall on the drive side sometime during the process? If so, you may very well have a bent hanger. Look at the bike from behind. Is the cage straight up and down or does the bottom of the cage turn inward slightly?
  1. A possible silver lining for conservatives...
    By desurfer in forum Politics Only
    Last Post: 11-06-2008, 05:29 AM
  2. Long or Short Cage R. Der. / Braze on F. Der.????
    By MnMike in forum Components, Wrenching
    Last Post: 02-21-2008, 04:26 PM
  3. rear der. not hopping to largest cog. Little help.
    By culdeus in forum Components, Wrenching
    Last Post: 02-13-2006, 06:33 PM
  4. Lining Up the Stem
    By chbarr in forum General Cycling Discussion
    Last Post: 06-17-2004, 10:40 AM
  5. Replies: 8
    Last Post: 03-03-2004, 04:52 PM
