Results 1 to 8 of 8
    Apr 2013
    New Sram Double Tap Sfifter do not shift
    I have converted from TT to road configuration with Sram Force Double Tap shifters. All installation done. Brakes work just fine.
    With proper shifter's cable tension on, all attempts to shift either derailleurs fail. Nothing append. How to correct this situation ?
    Reputation: AJ88V's Avatar
    Nov 2012
    Assume the shifter gear was working fine before you changed your setup.
    The obvious thing is that you have binding in the cable routing somewhere. Perhaps under the bottom bracket?
    Are your cables exposed or routed through the frame? If exposed, can you see the derailleurs move when you pull the cable slightly?
    What gear (big/small) is your rear currently on?
    'brifter' is a lame word.
    undo the cables from the derailleurs.
    pull lightly on them by hand, and try to move the shift paddle. if it doesn't work...
    remove cables from shifters, make sure right shifter is in 'high gear' position and left is in 'low gear'. (did you do this before installing cables? or were they new shifters w/ the shift cables pre-installed?)
    re-install cables.
    this is on the assumption that your derailleurs are working smoothly and there aren't any problems w/ cables/housing or cable guides.
    they're pretty simple and quite easy to work with. try the above and see what happens.
    2010 Cervelo T1 sprint bike
    Ruger 10-22TD
    Smith&Wesson M&P 15-22
    Smith&Wesson M&P 9
    oh, those belong in another forum
    Apr 2013
    Quote Originally Posted by AJ88V View Post
    The shifter gear was working just fine. Along with the new set of shifters, I also put on new cables and housings.
    I use a 2008 Cervelo soloist with cables routed through the frame. The rear gear is on the high gear (small cog)
    As of now, I have rear derailleur shifting smoothly all across the gears.
    Apr 2013
    re-install cables.
    This is a new set of shifters with shifting cables pre-installed.
    So far, I managed to get the right shifter working properly through all gears.
    I did not "right shifter is in 'high gear' position and left is in 'low gear' " ! That might be the root of my problem ! How do I get there ?
    Pathlete and Pedalphile
    Reputation: redondoaveb's Avatar
    Jan 2011
    Quote Originally Posted by PR0042 View Post
    While pulling (tensioning) on the cable, give your shifter the half (not sure if that's the right term) click. Keep clicking until you run out of clicks. Now you are in your lowest gear in front and your highest gear in the rear.
    If you try to fail, and succeed, which have you done?
    Nov 2010
    Re: New Sram Double Tap Sfifter do not shift
    This happened to me. The left shifter was shifted to the large ring position, so when I installed cable, it was already 'spooled up', so it could not pull the cable. Once I figured it out and snapped it down while pulling the cable, then reattaching cable to FD all was good.
    Apr 2013
    Quote Originally Posted by redondoaveb View Post
    Done ! All working as they should... even the part-time mechanic
    Thank you all for your help. Happy riding
  1. Shift cable stuck in SRAM Rival shift/brake lever
    By outhere in forum Components, Wrenching
    Last Post: 01-29-2012, 04:44 PM
  2. Sram Red RD -- won't shift into largest cog
    By mjdwyer23 in forum Components, Wrenching
    Last Post: 07-04-2009, 08:02 PM
  3. SRAM Multiple Shift
    By quarkrad in forum SRAM
    Last Post: 05-11-2009, 05:42 PM
  4. Double vs. Triple Shift Levers
    By lightband in forum Components, Wrenching
    Last Post: 11-26-2008, 05:44 PM
  5. Will a Shimano Triple FD shift on a double fine?
    By DIRT BOY in forum Components, Wrenching
    Last Post: 08-25-2006, 07:45 AM
Sea Otter Classic
Contest
