Results 1 to 6 of 6
    Aug 2012
    New Taillight For The Road
    Earlier this week I went to turn on my Cateye Rapid X taillight and the battery was dead. When I got home I plugged it in to charge. I left it charge for a couple of hours and it wouldn't turn on. This unit was my second unit in a row to brick after I accidentally let the batter drain to E.
    I really like the Rapid X due to its profile and brightness but I refuse to spend $45 a year on taillight. Yesterday after work I swung by my LBS and picked up a Niterider Omega 300 taillight. I went for a ride after work and it was starting to get dusk so I turned on my taillight. Holy frick is this new light bright! I would say it's twice as bright as the Rapid X and only cost $10 more.
    I'm hoping this light doesn't brick if it goes dead, and I know the issue with the other two were completely my fault, life happens.
    Point of the story is if anyone is on the market for a super bright taillight for $55 give the Niterider Omega 300 a look.
    Reputation: Lombard's Avatar
    May 2014
    A light should not "brick" if you let the battery run down all the way. So not your fault.
    I've been using the Cygolite Hotrod 50 for a couple of years and often run the battery through its cycle. No problems charging it. I ususally get 5 or 6 rides before I need to charge it again and it's very bright.
    Reputation: Notvintage's Avatar
    May 2013
    Cannot beat this rear light. It's a torch and compact. .
    https://road.cc/content/review/23188...akt-rear-light
    Reputation: nova_rider's Avatar
    Sep 2005
    Not a fan of built-in batteries for this exact reason. I prefer taillights that use AAAs, and I try to keep a set in the charger that is fresh ready to go. NiMH batteries also fare much better than Li-Ion during winter riding when temp dips below freezing.
    Reputation: Srode's Avatar
    Aug 2012
    Quote Originally Posted by nova_rider View Post
    Huh? I wouldn't own a light with NiMH, they suck - terrible life and memory issues etc. I've used Li-Ion battery lights at 7 below Zero F and haven't had a single issue, not interested in riding any colder than that.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Sep 2005
    At least I can simply replace these or slap in some alkalines in a pinch. While Li-ion works in cold, the run time suffers. Other symptoms I've seen with Li-ion are self-discharge when not in use and loses run time as it age. Not a fan of tossing a perfectly good light just because the built-in battery died. Regardless of chemistry, I find lights with replaceable battery are far more useful than non-replaceable ones.
  1. Loving my new Dinotte 140L-AA-R taillight
    By Mashmaniac in forum Components, Wrenching
    Last Post: 01-16-2009, 07:29 PM
  2. Brighter taillight, not for seatpost?
    By RedRex in forum Commuting, Touring and Ride Reports
    Last Post: 08-16-2006, 01:13 AM
  3. Need a cheap battery for NiteRider universal taillight
    By Folsom_Blues in forum Commuting, Touring and Ride Reports
    Last Post: 02-02-2006, 04:02 PM
  4. which niterider taillight do i need?
    By jh_on_the_cape in forum Commuting, Touring and Ride Reports
    Last Post: 11-17-2005, 11:03 AM
  5. Taillight users - do you remove your seatpost reflector?
    By nate in forum General Cycling Discussion
    Last Post: 09-13-2004, 06:02 PM
