Results 1 to 13 of 13
    Sep 2016
    New Ultegra 8000 compatibility with 6800
    Does anyone know if Shimano has stated whether the new Ultegra will be compatible with 9000/6800/5800?
    Specifically I'm wondering if the new rear derailleur and cassette will work with 6800 (hydro) shifters. Having an 11-34 on my CX/gravel bike would be nice for some of the steeper climbs around here.
    Jun 2008
    It'll work just fine, there was no change to the cable pull. R8000 is just a refinement of 6800.
    Forever a Student
    Mar 2014
    The change is in the front and it's with the crankset and chainring spacing.
    They're going to want the new crankset to be paired with the new front mech.
    Other than that it's all compatible.
    use a torque wrench
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Oh lord...don't tell me Shimano went and made a groupo that'll only shift right on Shimano's own extremely limited gearing choices....
    Forever a Student
    Mar 2014
    The new front mech will be good and solid and compatible with several cranks I imagine.
    So no worries there.
    The new cranks however *might* not work so well at all with past front mechs or front mechs from other companies.
    That's pretty much the deal.
    use a torque wrench
    Oct 2014
    Shimano if not going to add "Compatible with 3rd party components from Praxis, Rotor, Wolftooth, Stages and MORE.!" to their marketing. They are the market leader.
    Those companies are more than welcome to market components to fill the odd gaps in Shimano's products.
    Shimano's target customer with this group set is the mainstream built road bike market.
    The compact gearing available up to 11x34 is more than enough , even for the majority of the adventure bike crowd.
    Jun 2008
    The only difference is that the crank has moved the small ring inboard by .4mm and kept the large ring in the original position. The front derailleur has been profiled to allow it to move closer to the seat tube before it contacts and stops moving. Most bikes will have no issue here, but a handful may find their older derailleur may not be capable of moving far enough inboard to stop chain rub in the climbing gears. Not may bikes will have this issue, but a few will.
    Sep 2016
    At the end of the day will this matter? On both my 6870 and 5800/6800 bikes I run Quarqs with SRAM rings on them and they work fine.
    Are the new rings backwards compatible with older cranks?
    Oct 2014
    Quote Originally Posted by alxrmrs View Post
    It matters if the spacing between the rings is different ( which I believe is the case here ).
    Sep 2016
    What I forgot to add to this is that IIRC the spacing on SRAM 11 speed rings is slightly different than Shimano's own 4-bolt style.
    Jun 2008
    It matters, but it doesn't. Like I said, the change is so small that Shimano's own techs mix and match on their personal bikes, I've seen it first hand and it works just fine 99% of the time.
    Sep 2017
    chainrings?
    Anyone know if 6800 chainrings are compatible with r8000 cranks. Would you need to adjust the FD?
    Oct 2014
    Quote Originally Posted by spookiekabuki View Post
    The official answer from Shimano is "Nope!".
    The fact that the two have slightly different chainlines (*very slightly) probably matters quite a bit in this case.
    Then there is the physical and aesthetic differences (color, shape, etc..).
    I've never actually tried this, and personally wouldn't consider it. FWIW, I'm going to go with "Probably Not" compatible.
  1. Problem installing 6800 Front Derailleur FD-6800
    By TiCoyote in forum Components, Wrenching
    Last Post: 02-14-2015, 10:44 AM
  2. ultegra 6800 with apex crank compatibility?
    By BlazingSlow in forum Components, Wrenching
    Last Post: 03-23-2014, 07:08 AM
  3. Chain wrap capacity with 6800 and use of Force 22 crank with 6800
    By nkranhold in forum Components, Wrenching
    Last Post: 02-11-2014, 08:41 AM
  4. BB-8000 center sleeve installation necessary
    By jparman in forum Components, Wrenching
    Last Post: 08-27-2008, 06:58 PM
  5. Beware Possible Trek 8000 Scam
    By VTwood05 in forum Classifieds Feedback - Scam Warnings
    Last Post: 07-14-2004, 04:15 AM
