Results 1 to 8 of 8
    Sep 2012
    NewB building 1st bike under$300 need advice!
    This site is by far the goldmine for information. I'm starting my first ever bike build and trying to stay under $300. I know it's tough but CL will be my site to get parts as well as EBAY. I'll be installing everything myself as I got a LBS tools to use at any time I don't need the lightest part but just getting something that'll work. First item bought is a frame, BMC CX01, link below. List of things I need or will need.
    Frame: BMC CX01 56cm $32
    Fork:
    Handlebar:
    Wheels & Tires:
    FD:
    RD:
    Shifters:
    Seat Post:
    Crank:
    Bottom bracket:
    http://www.topangacreekbicycles.com/...ine_cx01-z.jpg
    First question, what would be the next item to buy? I'm looking at forks at the moment but unsure of which ones. I believe I need a 1 1/8 diameter fork.
    User is infamous around
    Reputation: junior1210's Avatar
    May 2013
    First check the head tube diameter, is it tapered or uniform diameter both top and bottom? Then check what kind of headset that frame requires. Then check what bottom bracket you'll need/want. Then check your frame to make sure the bottom bracket shell and head tube don't need to be faced (if it does, make sure whoever does the work is competent). Then have the headset pressed in and bottom bracket cups pressed or threaded in, then I'd worry about the fork and the rest.
    That's how I'd do it, but there will be disagreement to follow this post.
    Sep 2012
    Junior,
    Thanks for replying. I will take pictures to make sure if it's Tapered or uniform, im assuming tapered. Also, how would I go about checking what kind of headset that my frame requires?
    May 2013
    Basic research on frame should give that info, either from BMC's site or google, maybe even here. As far as the taper, it will be readily visible.
    wyrd bi ful rd
    Reputation: c_h_i_n_a_m_a_n's Avatar
    Mar 2012
    Headtube: 1 and 1/8th I believe.
    Bottom Bracket: 68mm English or BSA.
    Rear Axel: 130mm.
    Seattube ID: 31.6mm
    Any CX fork will be fine, but will need to be cantilever as your rear brakes are only cantilever, I believe.
    This was the fork recommended/sold by vendors when it was available.
    NewB building 1st bike under0 need advice!-20130616-easton-ec90x-fork-forum.jpg
    So if you get something along those lines, you should be quite safe in terms of maintaining the geometry of the bike.
    More cowbell!
    Reputation: Cyclo-phile's Avatar
    Sep 2005
    Are there some zeros missing in the OP? $32 for a BMC frame? Is it cracked? $300 for a total build cost? A decent used wheelset costs more than that.
    DFL > DNF > DNS
    Reputation: PlatyPius's Avatar
    Feb 2009
    Re: NewB building 1st bike under$300 need advice!
    Quote Originally Posted by Cyclo-phile View Post
    Yeah, I'm trying to figure that one out too.... missing zero or troll or ???
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Sep 2012
    Yes 32 is correct sir. Frame was dropped and got paint chipped away. Seller got new frame.
  1. Replies: 9
    Last Post: 07-21-2011, 05:25 PM
  2. Building a Road Bike from Parts -- Need Advice!
    By projecthuxley in forum Bikes, Frames and Forks
    Last Post: 04-13-2010, 06:10 PM
  3. Building a bike, 9 or 10 speed??? NEED ADVICE
    By MnMike in forum Components, Wrenching
    Last Post: 02-22-2008, 07:34 PM
  4. Any advice on building an Urban Assault bike???
    By CoryJ in forum Beginner's Corner
    Last Post: 05-15-2006, 10:29 AM
  5. building my first TT bike...advice pls
    By BenWA in forum Bikes, Frames and Forks
    Last Post: 06-05-2005, 06:17 PM
Sea Otter Classic
Contest
