Results 1 to 4 of 4
    Apr 2015
    Newb Wheel Build Qs
    So building my second wheel and a couple questions.
    When applying wheelsmith spoke prep - do you let it dry fully before lacing? Or does it matter?
    After you've got the initial lacing down - and you're ready for the stand - apply lube at the holes correct?
    Thanks!
    a real member's member
    Jul 2016
    i apply lube to the spoke threads and use a q-tip to apply lube to the inside of the rim's spoke holes before lacing.
    Sep 2011
    I let the spoke prep dry. I apply a thin coat of it to the threads, so you can just see it fill the space in them. I use Phil Wood oil when tensioning.
    Feb 2002
    Quote Originally Posted by jmcg333 View Post
    First question: why not post this in the Wheels and Tires section of the forum?
  1. Build or buy? Newb needs help.
    By whoiswes in forum Wheels and Tires
    Last Post: 08-21-2012, 11:17 AM
  2. Newb..bike build. Need to pick components and have lots of ??
    By Ronin101 in forum Components, Wrenching
    Last Post: 07-24-2010, 05:57 PM
  3. Replies: 43
    Last Post: 12-27-2009, 05:47 AM
  4. Newb Wheel Help
    By Chaos1 in forum Beginner's Corner
    Last Post: 07-10-2008, 11:04 AM
  5. newb wheel help
    By Pelon2 in forum Wheels and Tires
    Last Post: 04-19-2006, 08:42 PM
