Results 1 to 9 of 9
    Nov 2005
    Non-hidden bolt Red exogram ring experience
    The rings on my Force crank are due for a replacement. I was thinking of upgrading to the non-hidden bolt (read: standard) version of the exogram rings adding a Yaw front mech.
    If anyone has made this upgrade, what's your experience with front shifting performance?
    Reputation: vetboy's Avatar
    Oct 2005
    I replaced the previous generation Red rings w the new Red, non-hidden bolt on my Quarq about a month ago. I was already using the Yaw derailleur. The shifting is slightly better. I really had no complaints before, but the shifting is marginally better. Not sure I would recommend replacement just for the marginally better shifting, but if it's time to replace, go for it. I will say that the new rings are not cheap. I think the bigger improvement will be noticed because of the Yaw derailleur itself - I noticed a much bigger improvement when I switched to that.
    Good luck
    Joe
    Attached Thumbnails Attached Thumbnails Non-hidden bolt Red exogram ring experience-img_00000217.jpg
    Nov 2005
    Thanks Joe for the thoughts. I'm debating on the Exogram/Yaw combination or keeping my standard FD and replacing the worn rings with Praxis Works ones. I just wasn't sure how much of the improvement in shifting/stiffness was due to the spider design of the new red crank vs. the rings themselves and if I would notice a vast improvement over the praxis works and a standard FD.
    Oct 2005
    I think the Yaw derailleur is where the improvement is. I would definitely recommend that over the previous FD and new rings.
    Joe
    Reputation: looigi's Avatar
    Nov 2010
    I have the 2013 Red cranks and what I didn't know was if the ring holes that were hidden behind the crank arm were any different than the other 4 holes in a way that would be a problem from mounting the rings on the older style SRAM cranks that don't have the hidden holes. Evidently from your pic, they're not and will take the normal ring bolts/nuts.
    ... 'cuz that's how I roll.
    Oct 2005
    Quote Originally Posted by looigi View Post
    Not entirely correct. They actually make 2 different sets of rings - one for the "hidden 5th bolt" like you have, and one for a more standard "non-hidden 5th bolt" like in my pic. You could use the hidden bolt style (yours) on a non-hidden bolt (mine), but the peg that prevents the chain from getting wedged between crank arm and outer chainring would be in the wrong place. Clear as mud?
    Joe
    Sep 2002
    Quote Originally Posted by vetboy View Post
    Good luck
    Joe
    Why didn't you go with the ZED2 crank?
    Oct 2005
    Quote Originally Posted by ewitz View Post
    I did use it for a few months, but then I got a Quarq power meter.
    Nov 2010
    Joe
    Ahhh. Thanks for the clarification.
  1. Fulcrum wants $70 for chain ring bolt. WTF
    By Guppie58 in forum Components, Wrenching
    Last Post: 08-02-2010, 09:36 PM
  2. Tightening Chain Ring Bolt
    By leon2982 in forum Components, Wrenching
    Last Post: 03-24-2008, 05:36 AM
  3. Ritchey WCS Compact Crank Hidden Chainring Bolt
    By bikersteve in forum Components, Wrenching
    Last Post: 10-15-2007, 08:18 AM
  4. How to determine ring bolt spacing
    By DiRt DeViL in forum Beginner's Corner
    Last Post: 08-20-2005, 03:32 PM
  5. broken chain ring bolt ... can I still ride?
    By sherpa in forum Components, Wrenching
    Last Post: 05-18-2004, 04:37 AM
Sea Otter Classic
Contest
