Results 1 to 21 of 21
    ( ͡ ͜ʖ ͡)
    Reputation: old_fuji's Avatar
    Mar 2009
    Octalink v1 compatibility?
    Are there any sort of "generic" bottom brackets that are compatible with Octalink v1 cranks? I've read about v2 and v1 being incompatible, but what about something like ISIS-splined or something?
    I lost my phone number. Can I have yours?
    Old and Fixed, Moderator
    Jan 2002
    Quote Originally Posted by old_fuji
    ISIS and Octalink are different designs...The number of splines and shape are different.. I'm not aware of anyone besides Shimano making an Octalink BB..
    Dave Hickey/ Fort Worth
    ( ͡ ͜ʖ ͡)
    Mar 2009
    Quote Originally Posted by Dave Hickey
    Shucks...someone posted a link to a great deal on some octalink cranks, but I nearly cried when I saw the price for the appropriate bottom brackets.
    wim
    wim is offline
    Feb 2005
    Been using Shimano 105 Octalink BBs for quite some time now. They're not that expensive and seem to last. When comparing the price to outboard bearing BBs, keep in mind that you're also paying for the spindle when you buy Octalink. As said, Octalink is Shimano-proprietary and does not interface with anything but Octalink. V1 = road; V2 = mountain.
    http://www.google.com/search?sourcei...talink+BB-5500
    ( ͡ ͜ʖ ͡)
    Mar 2009
    Quote Originally Posted by wim
    I'm mostly comparing the price to the $20 square-taper Shimano BB that I bought last fall. Heck, that was even a special-order product from the LBS
    wim
    wim is offline
    Feb 2005
    Well yes, square taper is cheap. But that's because you can't hardly give them away. Haven't you heard how flexible they are? Studies have shown that square taper decreases your potential power output by 12.3 % compared to Octalink, and 15.4 % compared to outboard-bearing configurations.
    Reputation: Kuma601's Avatar
    They get so noodle like, the best combination is to pair them up with tomato sauce.
    Banned forever.....or not
    Aug 2002
    I still have a DA Octalink BB on my TT bike (never had a problem with it) I've still got the Ultegra Octalink BB, that I used to have on my Gunnar, for when that wears out.
    Dogbert.
    I>U
    The Trollinator
    Apr 2008
    The Ultegra octalinks are generally considered the best, and run forever.
    The 105s are much easier to find (and cheaper).
    The Dura Ace are adjustable style, and are more maintenance -- and generally considered not worth it (for most people).
    Jan 2002
    Quote Originally Posted by zriggle
    I love the DA BB....It's been bullet proof for me....
    ( ͡ ͜ʖ ͡)
    Mar 2009
    Alright, I pulled the trigger on those cranks, and actually did find some good deals on v1 octalink BB's.
    Aug 2002
    The secret to long life, for me, is to stop water infiltration. I do this by running a bead of grease around the spindle, on both sides, and then wiping it off and reapplying every month or so. (takes two or three minutes)
    Dogbert.
    I>U
    ( ͡ ͜ʖ ͡)
    Mar 2009
    Has anyone used the XTR bottom bracket?
    wim
    wim is offline
    Feb 2005
    Don't know what crank you have, so all I can tell you is "could work." XTR Octalink spindle lengths are 112.5 and 116 mm; 105, Ultegra and DA Octalink spindles are 109.5 and 118.5 mm. Chainline would be off a bit. At worst, inner ring of a road triple might not clear chainstay.
    ( ͡ ͜ʖ ͡)
    Mar 2009
    The Shimano 105...FC-5502
    According to Jenson, it's compatible with the XTR 952 bottom bracket...as well as the BB5500 and BB7700.
    wim
    wim is offline
    Feb 2005
    FC-5502 and Octalink v1 XTR 112.5 mm will work, sure. Because the FC-5502 is designed for a 109.5 mm spindle, your chainline will be off a bit. The question is: why XTR?
    Aug 2002
    Loose balls or sealed?
    The loose ball version was yanked off the market real quick and replaced with a sealed unit like the Ultegra.
    Dogbert.
    I>U
    ( ͡ ͜ʖ ͡)
    Mar 2009
    FC-5502 and Octalink v1 XTR 112.5 will work, sure. Because the FC-5502 is designed for a 109.5 mm spindle, your chainline will be off by 112.5 minus 109.5 = 3.0 mm. Not that big a deal on a derailleur bike, IMO. The question is: why XTR?
    No real reason, I was just curious.
    Jan 2002
    I've used high end and low end cartridge Octalink BB's...The only noticable difference is weight..and the weight is in a spot that least effects performance..Don't think you are getting a performance improvement buying a higher end BB
    Shimano cartridge BB's are bullet proof..
    If you are used to adjusting loose ball BBs, DA is the best in my opinion but if you are using cartridge, they are all similar in performance
    Any ride...
    Reputation: BOppy's Avatar
    May 2002
    Related Question: Since ultegra bb-6500 is no longer available, what's the better choice with a 9-speed octalink crank? 105 (bb-5500), or dura ace (bb-7700)... more than twice the cost, but I hate the concept of downgrading a bike with a mixture of ultegra and dura-ace components. I'll have the bike shop install either way, and I think they can nail the install on the dura ace if that is a concern. Is there any chance that the 105 really will perform noticeably more poorly?
    old school drop out
    Reputation: laffeaux's Avatar
    Dec 2001
    Quote Originally Posted by BOppy
    [FONT=Verdana]Related Question: Since ultegra bb-6500 is no longer available, what's the better choice with a 9-speed octalink crank? 105 (bb-5500), or dura ace (bb-7700)...
    If you're a competent home mechanic the Dura Ace is the nicer BB by far. Is it worth the money is your decision. The 7700 Dura Ace BB uses roller bearings instead of ball bearings, and can be re-greased as needed. The 105 works fine but is a sealed unit and will go in the recycle bin when the bearings get gritty. The disadvantage of the Dura Ace is that you'll need to know how to install the bearings to remove any play (it's not too different from adjusting a headset, and it's no different from removing play form a cup and cone hub). If you're someone who does not know how to work on a bike and don't want to learn, get the 105. If you don't mind maintaining your bike and you have the money, get the Dura Ace, it's lighter and will last many times longer than the 105.
    Also, re: v1 and v2 Octalink... v2 does not equal "mountain bike" BB. XTR used the same spline as all of the road groups, and was called v1. V2 was used on lower Shimano mountain bike groups: LX for sure, and I believe XT as well.
