Results 1 to 5 of 5
    Apr 2014
    Pedals won't release
    I've got this set of xpedo sl road pedals that I've used previously with no problems whatsoever. I took them off & stored them for a while as I didn't need them.
    On a new build, I decided to put these pedals back into use again. Clipped into them & found out on the test ride that I wasn't able to click out normally almost falling over. Turning the foot outward as normal only resulted in the foot twisting to a certain point where it should release but it didn't & the foot remained locked in & you couldn't twist back in either. The foot was stuck in a splayed position.
    I was only able to click out the other foot by twisting inward. Once I had that foot on the ground, I was able to twist the other foot inward to release it. I played with the tension & it really didn't do anything but make clicking in super easy. But even then the pedals don't feel right. They used to be really positive & snappy with the engagement when clicking in but now I can't even tell if I'm clicked in or not. Anyone else experience this before & what's the solution?
    BTW these pedals have never been ridden in the rain & actually have pretty low mileage on them. The cleats & shoes are brand new.
    Oct 2017
    Same xpedo cleats?
    Apr 2014
    Yep. Pedals came with 2 sets of cleats.
    Oct 2013
    What size are they?
    Try silicone spray?
    BANNED
    Dec 2012
    Stupid question, admittedly, but are you cleat screws tight? If you can release inwards, but not outwards, I'd say the problem is with the cleats not the pedals.
  1. I won! I won! I won!
    By CyreneSong in forum The Lounge
    Last Post: 08-26-2011, 03:40 PM
  2. Multi-Release Cleats vs Non Multi-Release Cleats
    By daniell in forum General Cycling Discussion
    Last Post: 07-19-2010, 02:54 PM
  3. Lateral Release Cleats vs. Multi-Directional Release
    By RoadHazard in forum Beginner's Corner
    Last Post: 09-04-2009, 11:44 PM
  4. NASA won't release results of air traffic study
    By FondriestFan in forum Politics Only
    Last Post: 10-23-2007, 05:56 AM
  5. Floyd won't release samples for further testing
    By Barry Muzzin in forum The Doping Forum
    Last Post: 02-14-2007, 03:36 PM
