Results 1 to 4 of 4
    Aug 2015
    PF30 Stages in BB90 frame?
    I have a Niner BSB9 (PF30) and considering a Trek Boone (BB90). Is there either an adapter to run this or a replacement spindle for my crank to make this work? I'm running a CX1 crankset with a Stages power meter, which has a custom Stages spindle. Maybe there's a different spindle replacement? I just want to avoid buying a whole new power meter in order to get a different frame.
    'brifter' is a lame word.
    No...
    I work for some bike racers
    and a bunch of skateboards
    Aug 2015
    No...
    I figured as much but wanted to check.
    Trek frames use the 'standard' axle size from the 3 big manufacturers...Shimano, the GXP from SRAM and Campy. They are all based on a 24mm axle, nothing larger (BB30) will fit. The frame is 90mm wide, if you do the math that's a standard English bottom bracket (68mm) + 2 11mm wide bearing cups that the threaded bottom bracket of old uses.
  1. Endura bb90 nylon washers
    By JackDaniels in forum Components, Wrenching
    Last Post: 03-23-2016, 12:59 PM
  2. Replies: 3
    Last Post: 10-24-2014, 07:10 PM
  3. Replies: 46
    Last Post: 08-27-2014, 07:55 AM
  4. BB30A on a non Cannondale frame with BB30/PF30?
    By Tommy d. in forum Cannondale
    Last Post: 08-09-2014, 01:05 PM
  5. Did I destroy my frame?? Pressing in a PF30 bb and POP...
    By Waspinator in forum General Cycling Discussion
    Last Post: 06-24-2014, 04:47 AM
