Results 1 to 7 of 7
    Aug 2012
    pivot spring position in Super Record 11 rear derailleur
    Ok....this is confusing...
    I was trying to adjust the rear derailleur on my son's bike (campy SuperRecord 11)...when I noticed the cir-clip was almost 1/2 out from under the mounting bolt. I guess when I installed it, the cir-clip caught on the thread & pulled out a bit. I removed the derailleur to fix it...and the clip popped out on me. I re-installed it, bit I cant seem to get it back together properly....the piece with the stop tabs seems to position at the top of the derailleur mounting bolt , instead of at the bottom...does the spring have to be wound to get correct position?
    Does this make sense to anybody??..I'm very frustrated by this...BTW I took it to a local shop, and they couldn't do anything...didn't want to touch it.
    Sep 2007
    Yes, the spring does need to be wound up.
    Aug 2012
    Quote Originally Posted by RHankey View Post
    how do you do that??
    are there any instructions on line how?
    thanks
    Sep 2007
    If memory serves me right from doing this on a couple non-Campy ders in years past, you need complete about 1/2 to 3/4's of a revolution (clockwise). The trick if I remember is getting the der past the stop nub without the end of the spring becoming dislodged again. Sorry, but I've not had any desire/need to pull apart my SR11 der or any of my other recent Campy ders that are otherwise working properly.
    'brifter' is a lame word.
    The easiest way would probably be to put a 3-way wrench in a vise and put the derailleur mounting bolt on the wrench. Then you can wind the spring up w/o having to hold the wrench w/ one hand. Just be careful when going past the stop so you don't scratch the body of the derailleur.
    I work for some bike racers
    and a bunch of skateboards
    Feb 2002
    Putting the Allen wrench in the vice helps but is not necessary. I use a small pair of Channel Lock pliers, which are good because you can keep the jaws parallel. You put the jaws around the bolt and they catch the tang that sticks out (that engages the dropout). You can easily twist the plate until it is in position and then you can use the pliers to push it down into the spring retainer "tube".
    Aug 2012
    Got it on by hand....what a pain!!
    I'll be careful not to do this again.
  1. Stripped rear cage on Super Record rear derailleur
    By tperez11 in forum Campagnolo
    Last Post: 07-14-2013, 09:39 AM
  2. Spring tension on 11sp derailleur upper pivot
    By tom_h in forum Campagnolo
    Last Post: 06-11-2012, 05:11 PM
  3. Rear Derailleur - Pivot bolt sizes
    By B05 in forum Components, Wrenching
    Last Post: 01-08-2012, 05:33 PM
  4. Campagnolo Record pivot bolt/spring
    By KATZRKOL in forum Components, Wrenching
    Last Post: 03-24-2007, 12:22 PM
  5. Ti Rear Derailleur pivot bolt for Campy 07
    By Whatever123 in forum Save Some Weight
    Last Post: 12-21-2006, 12:40 PM
