Results 1 to 6 of 6
    Oct 2003
    Post Mount Disc Brakee vs Flat Mount
    The bike pictured requires Post Mount disc brakes right? You cannot adapt Flat Mount brakes to fit? Pretty sure I ordered the wrong thing.
    ThanksPost Mount Disc Brakee vs Flat Mount-0492c615-e70e-4080-a9f9-18f9ca1bbeb5.jpgPost Mount Disc Brakee vs Flat Mount-f81dc93f-3b93-4071-a138-ff061e92b071.jpg
    'brifter' is a lame word.
    I'm not aware of an adapter that will let you install flat-mount brake calipers on that bike.
    I work for some bike racers
    and a bunch of skateboards
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Well....two different things:
    A) The rear caliper, the frame is I.S. mounting...so you can do flat OR post mount brakes, so long as you have the correct adapter to replace (or use) what is pictures. So you can use anything. I.S. predates the others.
    B) The front fork is post mounting. It basically requires post-mount brakes IIRC.
    I could be wrong but I don't see anything that allows going from IS to flat.
    Oct 2003
    I havenít seen anything that allows Is or Post to Flat. Bummer. Donít know what I was thinking. Time for a return.
    Jan 2005
    Quote Originally Posted by steel rider View Post
    IS mount to Post:
    Shimano Mount Adaptor Rear Post to IS | Chain Reaction Cycles
    There's lots of adapter widgets for this kind of purpose to sort through. The only one that I believe doesn't exist is flat-caliper to post-mount.
  1. Replies: 2
    Last Post: 12-24-2017, 12:27 PM
  2. Road Discs- Post vs Flat mount and QR vs Thru Axle
    By TDFbound in forum Bikes, Frames and Forks
    Last Post: 08-29-2017, 09:21 AM
  3. Replies: 8
    Last Post: 10-12-2007, 05:28 AM
  4. Flat after flat after flat after...
    By PaulCL in forum Wheels and Tires
    Last Post: 10-04-2005, 08:56 AM
  5. flat tire after flat tire
    By bent188 in forum General Cycling Discussion
    Last Post: 06-27-2004, 06:14 AM
