Results 1 to 9 of 9
    Oct 2010
    Rear Brake - 2009 Felt B12 (Tri Bike)
    Just picked up this frame and does anyone know if it needs a specially configured rear brake caliper since it sits behind the crank at end of chain stay? Looks like pulling arm may be restricted by seat tube
    Thanks!
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Born to chase Ducks
    Reputation: Don4's Avatar
    Jul 2010
    Just in case you weren't aware, Felt does have a forum down in the Manufacturers section, and the Felt Road Brand Manager, Superdave, regularly participates.
    Oct 2010
    Thanks! - will re-post in Felt branded forum
    'brifter' is a lame word.
    Quote Originally Posted by frdfandc View Post
    actually, the brake that Tektro supplied us for the B2 frames (which is basically the same as the B12 at that part of the frame) is the R920 dual pivot caliper. i think either would probably work just fine, i've just never tried to fit a 725 series brake on one of these frames.
    I work for some bike racers
    and a bunch of skateboards
    3T Cycling
    May 2009
    Quote Originally Posted by s54chris View Post
    Thanks!
    The best one I've found to date is the TRP T-925-1B U-brake with the rear dual pivot mounting plate. It gives you plenty of crank arm clearnace and Tektro even offers a flexible noodle with a barrel adjuster so you can easily make adjustments between training and race wheel widths.
    The other excellent choice is the Dura-Ace BR7800 caliper (not 7900, not 9000, not 9010). This rear tucks neatly into the space above the BB and is narrow enough not to interfere with the crankset.
    You'll find others with this patented brake location to use the Dura-Ace caliper on their bikes like Scott, Lapierre, Koga, etc....even when the rest of the components are SRAM or 7900 because of the clearance + performance it offers.
    -SD
    Feb 2002
    Time passes
    Quote Originally Posted by SuperdaveFelt View Post
    Yeah, but since this question was posted nearly a year and a half ago, I'm guess the OP has already purchased the brakes.
    3T Cycling
    May 2009
    I'm guessing that he may not be the only one looking. My hope was to provide some help for him or anyone that found the thread in a search. That is why I replied despite the lapse in time.
    Why did you reply?
    Reputation: Fireform's Avatar
    Dec 2005
    Actually this is quite helpful for my B2 Pro. Unfortunately I sold off a set of 7800 brakes before I got the tri bike.
    Arguments among misinformed people do not constitute a "debate."
    --Kerry Irons
    "Atheism is a religion like not collecting stamps is a hobby."
    --BianchiJoe
    Cervelo S3/Dura Ace
    Felt B2Pro/SRAM
    Cannondale CAAD10/105
  1. Felt 2009
    By esenkay in forum Felt
    Last Post: 07-09-2009, 01:00 PM
  2. 2009 Felt F1 SL
    By Campy-on-a-Trek in forum Felt
    Last Post: 06-24-2009, 11:25 AM
  3. Felt F3SL 2009 or new LOOK 566?
    By Rolls in forum Bikes, Frames and Forks
    Last Post: 06-23-2009, 05:51 PM
  4. Felt F3SL 2009
    Last Post: 08-10-2008, 07:05 PM
  5. rear spooky setup for bike without brake bridge - help!
    By bicyclenerd in forum Cyclocross
    Last Post: 10-06-2005, 01:01 PM
