Results 1 to 6 of 6
    Apr 2009
    Removing freehub from DT R470 wheels with thru axle
    Trying to service my freehub and the thru axle seems to be making the process different than the service videos on the DT site. Usually I can just leave the cassette on and pop that bad boy off, but even using a vice to hold the other side of the axle doesnít seem to be working. It looks like thereís a reverse threaded end cap instead of the usual press fit ones, but I could be wrong. This is on a brand new Roubaix FWIW. Any tips?
    Feb 2010
    The hub is not a r470. The r470 is a rim.
    What year/model of Roubaix is it?
    Apr 2009
    2018 Roubaix Elite
    Sorry for the mixup on the naming, Specialized calls the whole wheel set a R470:
    https://www.specialized.com/us/en/ro...=240076-128886
    Feb 2010
    Weird. I don't stock that model in the shop, and Specialized's dealer website/service parts finder also simply show it as a wheel. No idea what hub is on that bike.
    You're not going to find any instructions on the web until you figure out what kind of hub is spec'd on that bike. Give the dealer you bought it from tomorrow, they'll be able to call Specialized and hopefully get you some answers. Also, if you go into the dealer they'll probably just figure it out.
    Apr 2009
    Thanks, was going to go to the dealer if needed, was hoping this would be easier to figure out on my own.
    Apr 2009
    Ok I figured it out. Definitely not a DT hub so Iím guessing itís one of their Axis ones. Had to remove the centerlock disc, and then one side of the end caps comes off ala pressfit. That exposes the axle with two holes in it, which you can stick an Allen key through for leverage while you unscrew the reverse threaded endcap on the other side of the hub. After that, freehub pulls right off.
  1. Removing freehub from DT R470 wheels with thru axle
    By Tarekith in forum Wheels and Tires
    Last Post: 6 Days Ago, 11:40 AM
  2. DT Swiss R470 db
    By gasman777 in forum Wheels and Tires
    Last Post: 03-07-2018, 08:34 AM
  3. DT Swiss R470 db?
    By dmanthree in forum Wheels and Tires
    Last Post: 12-31-2017, 07:54 AM
  4. Question about thru-axle wheels on road bike
    By Trek_5200 in forum Wheels and Tires
    Last Post: 02-29-2016, 01:03 AM
  5. Replies: 20
    Last Post: 03-19-2008, 06:48 PM
