Results 1 to 17 of 17
    Jan 2012
    Replacement for Shimano C101 Front Derailluer
    I have a Giant Cypress with a Shimano C101 front derailleur. The bike has three front chain rings and 7 rear cassette. The front derailleur has a great deal of play and so bad I'm afraid it's coming apart. I tried to order a replacement from Performance Bicycle, but they did not have anything that would work and sent me to Nashbar. Nashbar did have a replacement part, but it had to be back ordered. The ship date has been moved back several times since the original order. Can any one offer a suggestion as to a derailleur that would replace the C101 or another supplier that I might try? Thanks for any suggestions.
    a real member's member
    Jul 2016
    ebay?
    JSR
    JSR is offline
    Feb 2006
    It may be the FD-A073. It's in the Shimano Tourney model group. It's only road triple for 7-speed I could find.
    http://productinfo.shimano.com/downl.../2.3/en#page39
    https://www.amazon.com/Tourney-Shima.../dp/B00U0NQFFG
    Jan 2012
    Thanks for the suggestions.
    wim
    wim is offline
    Feb 2005
    Chances are you can ditch that C 101 and replace it with a mountain bike front derailleur. It doesn't matter if your C 101 is the nasty E-type (attached to the bottom bracket). I've taken a number of E-types off bikes and replaced them with clamp-on front derailleurs.
    Bring the bike to a shop whose owner or manager can think outside the box. Number of speeds don't matter much since cages can be slightly widened or narrowed if needed with some very basic tools.
    Mar 2013
    Quote Originally Posted by blackfrancois View Post
    ebay?
    I can hardly find anything on there anymore...
    May 2014
    Is it definitely the FD that is the problem? If you have the Suntour crank (48/38/28), as the current Cypress does, those chainrings are very prone to bending. I am UK based so I have no idea f these prices are good, but there are some inexpensive cranksets on here if your chainrings are bent.
    7 Speed Crankset at bikewagon
    Reputation: Srode's Avatar
    Aug 2012
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Jan 2012
    Thanks All. JSR I ordered the FD AO73 from Universal Cycles, should have it next week. Riccardo that is the crank set I have, I just put a new one on two weeks ago. I don't know if it was bent, I replaced it because I had ran a chain too long and had to replace both the cassette and chain ring...........won't make that mistake again! The FD had seemed to me to have way too much play for some time so decided to change it out while I'm in the mood. Thanks everyone, I greatly appreciate all the advice. Jay
    May 2017
    Quote Originally Posted by JayEInd View Post
    How did the FD-A073 work for you?
    I also have a Giant Cypress. I've owned it for nearly 4 years and bought it off Craigslist. I've replaced pretty much all the components everything on it over time and wheels and learned a lot about bikes! I haven't touched the front of the drive train yet (derailleur, crank set, chain rings). I think about retiring this thing from time to time but it's been a dependable daily commuter (10 Km return) for me for a few years now.
    Anyways, the front derailleur won't change to the small chain ring most of the time (I replaced the shifters and tried adjusting the H/L and also pulled apart the derailleur but I think the recoil spring is just toast or the thing is just overall tired. The large chain ring teeth have seen better days and shifting up there could be smoother... I'm thinking of replacing the crank set, chain rings and the derailleur. Anyone have a suggestion on cheapish crankset? I'm running a non-replaceable chainring crankset that is 28-38-48T w/ Shimano FC-C103 markings. I believe this is a square taper and cranks measure 170mm centre to centre.
    Lastly... Is the only reason to replace the bottom bracket is if there is play? Sounds like the width can be different...
    Cheers.
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by turb0chrg View Post
    A few things here:
    1) Are you sure the cable is adjusted slack enough so the derailleur can drop that low? Even if the H/L is adjusted properly, the cable tension could be an issue too.
    2) If your cables are old or the cheaper galvanized ones, they will get rough with time and use. Rough cables mean they won't slip and slide through your housings, resulting in poor shifting. The best (and cheapest) thing you can do for your shifting is replace your cables with good quality stainless steel cables. While galvanized cables oxidize and become rough, stainless steel cables stay smooth. If your housings are old, it won't hurt to replace those too.
    3) It is entirely possible that your derailleur spring is gunked up. Give it a squirt of WD-40. Derailleurs seldom go bad. With very high mileage and rough use, they can develop play, but that is quite unusual.
    The 28/38/48 crankset you have is a difficult one to find a replacement for in a square taper. The closest thing there is to this is one made my Sugino:
    Sugino Xd2-350T 26/36/48X170Mm Lp Crankset Silver | eBay
    It is actually a 26/36/48 which is pretty close and will give you even better hill climbing ability. It is marketed as an 8-speed crankset with an emphasis on marketed. It will work just fine with your 7-speed as the chain width isn't different enough to matter.
    Yep. You will know when the bottom bracket goes south as you will get a clicking or creaking sound that is cyclical with your pedaling. That is the first sign there is play.
    Oh yes, absolutely! You need to get the correct width and thread size for your frame. The best way to find out what you need is to take the old one out and look what it says on it.
    -- Warren Buffett
    May 2014
    You can get this one with square taper
    Buy Shimano FC-M311 Altus Square Taper Chainset at Tredz Bikes. £27.98 with free UK delivery
    Sorry for the UK link but I'm sure you can get it elsewhere.
    May 2014
    Quote Originally Posted by riccardo123 View Post
    It looks like you can get it on Amazon. And it's only $34 with free shipping if you spend $50 or more on the same order:
    https://www.amazon.com/Shimano-Altus...XR6?th=1&psc=1
    -- Warren Buffett
    May 2017
    A few things here:
    Thanks for the tips. I've done 1-3 already. I replaced the cables when I did the shifters. When I disassembled the derailleur I greased it up too...
    I think I might be onto something with it. I bent the cage a bit and things worked better for while, now it's back to the way it was before. Perhaps the cage metal is just not rigid enough anymore. I found Front Derailleur Adjustment | Park Tool and will give it a thorough look before I replace this thing!
    Cheers
    May 2014
    I hope you didn't use grease. WD-40, my friend. Anything heavy will just gunk it up.
    -- Warren Buffett
    May 2017
    Heh, semantics;) I used this stuff https://www.mec.ca/en/product/1899-129/Lube-2oz
    May 2014
    OK, just making sure.
    -- Warren Buffett
  1. replacement cones for front hub on shimano rx100/hb-a550
    By cityrider in forum Components, Wrenching
    Last Post: 04-26-2012, 02:57 PM
  2. Front derailluer adjustment help?
    By GT554 in forum Components, Wrenching
    Last Post: 04-27-2010, 07:57 AM
  3. Rival Front Derailluer
    By C Dunlop in forum SRAM
    Last Post: 09-08-2009, 04:41 AM
  4. Front derailluer problems
    By Streamwood Steve in forum Components, Wrenching
    Last Post: 02-05-2009, 05:25 AM
  5. which late model shimano front dr as replacement?
    By warren128 in forum Components, Wrenching
    Last Post: 04-02-2008, 05:40 PM
