Results 1 to 10 of 10
    replacing Campy ergo hoods
    My hoods were in bad shape so I have some new one's coming from PBK, Is there a trick to installing these? These are pre-2008 ergo hoods
    Frog Whisperer
    May 2003
    Quote Originally Posted by DaveG View Post
    windex is a reasonable lubricant that will not leas a sticky residue or damage the rubber. slow and careful will get it done (or rubbing alcohol)
    Of course I'm sure...that doesn't mean I'm right.....
    "There's no sense being stupid unless you show it."
    "that was like trying to teach a goldfish how to play basketball over the phone."
    Big is relative
    Reputation: bigbill's Avatar
    Feb 2005
    I used talc and some patience. Some people use hairspray but it leaves a residue. Talc eventually works its way out.
    Retired sailor
    Jan 2009
    Drop the hoods into a bowl of warm tap water which will soften them slightly, and the water is all you need as a lube. Then it's simply a matter of stretching them over the brake lever while it's still on the bar. Massage it into place, and you're good to go.
    Note new hoods are easier to install than older ones which may be dried out or nicked and prone to tearing when stretched.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Thanks all for the advice
    Quote Originally Posted by FBinNY View Post
    I used the warm water approach although I think the other approaches would have been fine. My initial worry was getting the hoods over the knob at the top. That turned out to be quite easy. More difficult was massaging the hood into the correct position. Still not so hard.
    Reputation: GRAVELBIKE's Avatar
    Sep 2011
    Isopropyl alcohol works great as a lubricant for installing hoods.
    GRAVELBIKE.COM - ride everything
    Hide Age and DOB
    May 2007
    Fuuny, I have been trying to post this video for three days and kept getting the Anonymous garbage. Anyway it shows how the techs do it. http://www.youtube.com/watch?v=ZNcZ6ibkb-4
    E fatto espresso divieto di partecipare alla manifestazione con biciclette che non possiedano i suddetti requisiti.Ogni tentativo di farlo a mangiare un piatto di grandi dimensioni di 3 settimane la polenta e in genere di divertimento, soprattutto se egli straniero.
    Feb 2002
    Dihydrogen oxide
    Quote Originally Posted by GRAVELBIKE View Post
    So does that old standby dihydrogen oxide (generic name: water).
    Feb 2007
    Make sure you apply lots of good humor and a 6 pack of beer. It's a long, annoying fiddly job and will take you some time if you haven't done it before.
    Feb 2002
    Rove you rong time
    Quote Originally Posted by gordy748 View Post
    Or less than 5 minutes if you're actually watching the clock.
