Results 1 to 13 of 13
    Mar 2018
    Road Bike Rear Brake Spongy and Rough
    My road bikes rear brake is spongy, rough, and hard to pull. I have a Diamondback Podium 4 carbon bike with internal cable routing and the brake has been crap from the first day I bought it. It has Shimano 105 shifter/brake levers.
    I thought that maybe the cable housing was too long or getting hung up in the body so I replaced both the front and rear brake housings and cables with Shimano brand cables and housings. The front brake improved but the rear brake is still terrible and I can't for the life of me figure it out. On top of that now the rear derailleur is extremely hard to push up to the next gear with the lever which boggles me since I didn't touch either of the derailleurs cables or housings.
    Does anyone have any idea what might be the problem? I know it's not the brake pads or the wheels.
    Dec 2006
    I'd try, just for test purposes, to run full housing from the lever to the rear brake OUTSIDE of the top tube. Test it in the stand and see if it feels better. That will tell you something.
    Before you run the test, remove the cabling and squeeze the lever to see if there's any resistance with no cable connected. Then squeeze the brake caliper by hand to see if it's binding.
    Are you sure you're using BRAKE housing for the brake and not derailleur housing? After you cut the brake housing, you should file the end of the spiral wound housing so that it's nice and flat, with no burrs. A bench grinder is a godsend for this task, although I use a regular file and a little patience.
    Once you solve the brake issue, we'll try to address the change in derailleur performance.
    Mar 2018
    Yes I purchased a Shimano brand brake cable and housing set.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    I had clean cuts and ground the ends smooth using my angle grinder. I will check the lever for smoothness under no cable load. I do have a feeling it may be something in the top tube. The bike has an internal sleeve in the carbon fiber top tube so I didn't have to do any cable fishing. I have had the thought that maybe they screwed up this internal tub when they cast the carbon frame but am not sure.
    Mar 2018
    Also the shifting was fine before hand. The only thing I did was remove bar tape and tape holding the cable down to the bar. Then replaced the tapes. How would that cause the new extreme difficulty in pushing the level up a gear?
    Dec 2006
    I don't have an answer to the shifting problem-yet. That's why I want to solve the braking issue first-I'm stalling for time!
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    Quote Originally Posted by Stockfoot13 View Post
    A possibility is that you may have wrapped the bar tape too tightly, which could distort the shift cable housing and cause your issue.
    Trying to cram the rest of my life into the rest of my life!
    Reputation: velodog's Avatar
    Sep 2007
    When you retaped the bars could you have altered the shift cables in such a way as to cause it to bind?
    Too old to ride plastic
    'brifter' is a lame word.
    Quote Originally Posted by DaveT View Post
    You're kidding, right?
    I work for some bike racers
    and a bunch of skateboards
    Nope. I made the assumption perhaps in error, that the OPs bike might be fairly new and have the shift cables under the bar tape. Years ago I installed the then new 6700 shifters and very tightly wrapped my bars. The bike had terrible, sluggish shifting until I untaped the bars and miraculously it shifted perfectly. I changed out the housing that was underneath the tape and less vigorously retaped and itís been perfect ever since.
    Sep 2007
    Try pinching the calipers together so the brake cable is slack and them apply the brake lever. If still sluggish I would think cable or lever issue but if smooth operating I would assume caliper issue.
    Sorry, but there's no way that more tightly wrapped bar tape will have any affect on shifting. There has to be something else that caused that. I wrap shift and brake housing as tightly as I can w/ electrical tape then wrap the bar tap very tightly so it won't slip. Never had a problem related to that and I'm talking thousands of examples. No way you can 'smash' housing w/ tape.
    Sep 2007
    I would guess that the housing shifting when you tightly taped the bars is what caused the cable drag.
    Reputation: Lombard's Avatar
    May 2014
    Or an inadvertent kink in the cable/housing somewhere.
    ďStatistics are like bikinis. What they reveal is suggestive, but what they conceal is vital.Ē -- Aaron Levenstein
    -- Warren Buffett
  1. Stiff frame = rough ride...how rough are we talking
    By rs_herhuth in forum General Cycling Discussion
    Last Post: 03-29-2012, 05:43 PM
  2. Cane Creek 200TT levers feel spongy
    By f3rg in forum Components, Wrenching
    Last Post: 10-15-2009, 03:22 PM
  3. Are Northern Marin/Sonoma road too rough for road bikes?
    By max_n in forum Northern California
    Last Post: 07-25-2009, 07:59 PM
  4. Sheldon Brown/Spongy Brakes
    By S2H in forum Components, Wrenching
    Last Post: 07-21-2006, 05:49 AM
  5. spongy shifting
    By greyghost in forum Components, Wrenching
    Last Post: 12-07-2004, 09:41 AM
