Results 1 to 6 of 6
    Feb 2010
    Road Stem Advice
    Hi all, considering a new stem, thinking of either 3T ARX Pro or Ritchey WCS 4 Axis. Both would be 6 degree, 120 mm. I think the Ritchey is a bit lighter. Which would you prefer and why? Thanks for any thoughts.
    Reputation: sherlock's Avatar
    Aug 2011
    I went for the 3T ARX Pro. Looks to be about 40g heavier than the Ritchey (150g vs. 110g @ 100mm). To be honest though, functionally they're both pretty good, and the 3T has good reviews re: stiffness.
    It just so happened that the white stripe on the 3T matches the white stripe on the top tube of my Felt...
    Born to chase Ducks
    Reputation: Don4's Avatar
    Jul 2010
    Quote Originally Posted by sherlock View Post
    That's funny! I got the 3T ARX Team, which has a red stripe, to match the red stripe on my Felt F3!
    Quote Originally Posted by MarkS View Post
    I cannot decide whether the seafoam green Lounge kit is cursed or a suit of armor that protects us...like a lycra St. Christopher's medal.
    Jun 2008
    I'm a big fan of Syntace products. I have this stem on 2 bikes. I used to have the FSA 0s-99. This is stem is a lot stiffer.
    Syntace
    Dec 2005
    I've used both at 6 degree. They felt identical. I'd just pick the one you like based on looks and/or price. My 3T Pro weighed in at 145g and the Ritchey was lighter but I don't recall the weight. This is for the 120mm 6 degree...I use the 3T only because I had to buy a new bar which was 3T and wanted the stem to match.
    Reputation: looigi's Avatar
    Nov 2010
    I have a 110mm -17 degree 3T Team stem and weighed it at 129gm.
    I don't believe stiffness is a factor in choosing between stems.
  1. Handlebar/Stem advice
    By Weav in forum Coaching
    Last Post: 06-27-2011, 03:25 AM
  2. Advice On Stem Lenght
    By supraholic in forum Components, Wrenching
    Last Post: 01-25-2011, 06:29 PM
  3. Bar & stem advice
    By Kuma601 in forum Retro-Classic
    Last Post: 06-03-2010, 12:59 PM
  4. Stem Advice
    By crazyquick23 in forum Bikes, Frames and Forks
    Last Post: 05-14-2008, 01:45 PM
  5. Advice - replacing stem
    By ahumblecycler in forum Components, Wrenching
    Last Post: 10-17-2007, 09:15 AM
Sea Otter Classic
Contest
