Results 1 to 10 of 10
    Reputation: SweatBlood's Avatar
    Aug 2008
    Rolf Vector Comp Freehub
    I'm not sure which year my wheelset is from but the rear wheel has 20 spokes and the hub bearing is the cup and cone style. Recently my shifting has been sketchy and when I really get on it I've been slipping a tooth here and there. When I was rebuilding my hub the other day I noticed that there was a bit of play in my freehub.
    Could anyone tell me exactly what freehub is on my wheel? Is it serviceable? Are there any other compatable brands?
    Aug 2008
    bumpity
    ARP
    ARP is offline
    Mar 2002
    I had a set of Comps warrantied by Trek
    Quote Originally Posted by SweatBlood
    Check with the LBS that sells Trek for some info. Trek and Rolf had a biz deal on his wheels and their bikes and then that went south and Bontrager became the big kid on that block. Mine (freehub) failed and was replaced by a set of Bontragers.
    Apr 2004
    Hugi Hubs
    I have the same set of wheels and have had to replace the cones on the rear hub, and found that these are Hugi Hubs. So you might want to start there or possibly even contact Rolf Wheels to see what parts they recommend.
    Aug 2008
    Quote Originally Posted by jammer
    I just had to replace the cones as well (they looked like the surface of the moon). I kind of figured they were hugi hubs I just wasn't sure whether they were the 244's or Onyx. I've been as sick as a dog all week. I suppose when I'm better I'll totter on down to my lbs and see if they have any idea (although their usual reply is ... "we look everything up on the internet just like you" ).
    Sep 2006
    i dont know if you are talking about the same problem im having, i have the same wheelset and the rear wheel is loose and i checked the skewer thinking it was loose but its fine, so the wheel has a very significant play on the rear, very loose and i clueless of what the problem might be, can you tell me what could it be?and if i need to replace the wheel, where can i get descent wheelset for a good price?
    Aug 2008
    Quote Originally Posted by skilldunker2381
    When you say the wheel is loose ... what part of the wheel? When the skewer is tightened can you move the rim side to side? Or does the cassette just have a wobble to it? As for replacements ... I just went from lbs to lbs asking if they had a matching one laying around. Eventually I found one and they threw in the dura-ace cassette that was on it too.
    Sep 2006
    the rim moves side to side
    Aug 2008
    yikes ... depending on what type of bearing you have in your hub it could be that (although that's pretty radical ... basically you would have had to break a ball in your bearings)... also make sure none of your spokes are broken. If it were me I'd probably just pick up a new wheel.
    Reputation: fleck's Avatar
    Mar 2005
    got a little play in my rear as well. Same vector comp. Learned the hard way not to mess with sealed bearings...
    i've been using them for CX so i'm sure that didn't help...
