Results 1 to 8 of 8
Thread: Rotor Wear
    Jun 2015
    Rotor Wear
    Hydraulic Disc Brakes
    Shimano Ice Tech Rotors
    This is the front rotor. I have 300 miles on it.
    The rear Rotor is wearing a little smother but the front one is not wearing in very smooth
    Is this wear pattern normal for them for a while ?
    Russian Troll Farmer
    Sep 2016
    To me, it looks OK. Keep in mind that those cutouts will wear a bit differently, due to being site-hardened by the process of making the cutout (most likely stamping, but maybe an EDM process), as will the edges. As long as the areas showing less or no wear correspond with the contours of the disc, things are OK. If you start getting radial lines, or 'corrugated' wear, THEN you have a problem.
    "L'enfer, c'est les autres"
    Jun 2015
    Thanks for the reassurance that things are ok
    I do notice that the other side of the rotor is not so pronounce wear with the cutouts (smoother wear) so the "stamping" method makes sense.
    Thanks for looking and your opinion
    Nov 2014
    They're fine, in fact, they're just getting broken in. It takes a long time to wear rotors down to the point that you need to replace them.
    'brifter' is a lame word.
    That's not an Ice Tech rotor. And as previously posted it's not only not worn out, it's barely broken in.
    I work for some bike racers
    and a bunch of skateboards
    Jun 2015
    No...It's not worn out.....It's brand new with only 300 miles on it.
    Funny.....It says Ice Technology on it
    Forever a Student
    Mar 2014
    It's not an Ice Tech Freeza. The one you have is sort of middle of the road. But yeah, whatever.
    use a torque wrench
    That is definitely not an alloy cored steel clad rotor.
  1. Rotor 3D Plus
    By SirVelo' in forum General Cycling Discussion
    Last Post: 04-24-2014, 07:09 AM
  2. Rotor Q chainrings
    By Conviccted in forum Components, Wrenching
    Last Post: 04-03-2012, 03:25 AM
  3. Shoe Fit... to wear or not to wear
    By El Caballito in forum General Cycling Discussion
    Last Post: 03-12-2009, 11:46 AM
  4. Chain wear = crank wear & cassette wear? true? false? bs?
    By jakerson in forum Components, Wrenching
    Last Post: 08-15-2006, 11:55 AM
  5. cassette rattle/wear & chain wear
    By the flying bean in forum Components, Wrenching
    Last Post: 02-23-2005, 05:13 AM
