Results 1 to 8 of 8
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Running (older) Mavic SUP rims tubeless...am I gonna die?
    RIMS, not tires! (Typo)
    So, this is self explanatory. I have a Mavic SUP (road) wheelset that I want to convert to tubeless. It is probably 15-16 years old. We had no problems converting mountain rims to tubeless BITD, but those are MUCH lower pressures.
    Anyone have real experience with ghetto tubeless for road/CX?
    I want to try this with tubeless tires, obviously.
    Researched a bit, the answers are all over the place.
    Apr 2014
    Ahhh, its definitely a no go. A tubeless rim is different from a normal rim. Your old rims have nothing to lock the tire in place. Its not as simple as just using the proper rim strip to provide the air tight seal & you're a go.
    You could try it but the tire would most likely just blow right off. If the rim does't say tubeless ready, then there's a good chance you may die. So go for it.
    a real member's member
    Jul 2016
    here's a "tubeless hack."
    Feb 2005
    Quote Originally Posted by blackfrancois View Post
    Right...but that's for Mountain (lower pressures). I set up hundreds of wheels like this at my old shop...
    'brifter' is a lame word.
    Don't do it. Good reason it's called a 'hack'.
    I work for some bike racers
    and a bunch of skateboards
    Jul 2016
    sorta fitting* to make a tubeless hack with a hacked tube, though.
    * or ironic, whatever.
    Reputation: Lombard's Avatar
    May 2014
    Some hacks work, some hack don't. This hack may kill you. As the saying goes "Don't try this at home".
    Feb 2005
    Upon further reflection, I think any fast section I would be riding on (and there are lots of FAST sections around here) I would be contemplating my mortality at 40 mph.
    Too scared of the consequences.
    Not gonna do it.
    Might rebuild the white industry hubs with tubeless rims, though!
    EDIT: What I'm finding, however, is that rim brake tubeless rims are nearly impossible to find at cost.
  1. Replies: 6
    Last Post: 04-03-2013, 11:18 AM
  2. Mavic OP SUP and Mavic hubs any good?
    By e39540is in forum Wheels and Tires
    Last Post: 04-25-2011, 03:22 AM
  3. Mavic SUP cermaics 36/36 vs 32/36
    By bolo yeung in forum Wheels and Tires
    Last Post: 07-30-2010, 10:09 AM
  4. Mavic SUP - know anything?
    By tober1 in forum Wheels and Tires
    Last Post: 04-06-2010, 07:43 PM
  5. Mavic open pro...what is the SUP decal?
    By Bikerchris in forum Wheels and Tires
    Last Post: 04-17-2005, 01:44 PM
