Results 1 to 5 of 5
    Jan 2006
    Sella Italia SLR Kit Carbonio & LUBE?
    Dear members
    I ride a Trek Madone 5.9 full carbon bike (2004 model), which came with the blue San Marco Aspide saddle with Team United States Postal Service embroidered on it.
    Recently, I have noted a creaking sound when I pedal (sitting), and my riding buddy and I believe we correctly isolated it to the saddle. Thinking the seat may have been cracked, I have replaced it with a SELLA ITALIA SLR KIT CARBONIO.
    Today we went for a ride and definitely much less creaking (none for the first 20 kilometers), but then it started again, but only very infrequently.
    I thought the problem may be where the rails join the seat's shell at the front and the back.
    Is there any chance of damaging the saddle (SELLA ITALIA SLR KIT CARBONIO - carbon & vanox rails, carbon shell) by lubricating (with a synthetic oil - Protecta) the points where the rails join the shell?
    If not, I'm gonna try it.
    Dave V.
    Geelong, Australia
    cmg
    cmg is offline
    Reputation: cmg's Avatar
    Oct 2004
    put grease/lubricant where the saddle rails are attached to the post. that is probably where it is creaking from. also put some on the seat post where it meets the seat tube and tighten appropiately. i did this and it stopped the creaking on my saddle.
    Jan 2006
    Quote Originally Posted by cmg
    Thanks.
    1. Will carbon seatpost on carbon frame be a slippage problem?
    2. Will the lube damage the carbon seat where the rails meets the shell, because I've already lubed it there!
    Reputation: Wild Bill's Avatar
    Apr 2004
    Quote Originally Posted by Dave V.
    Thanks.
    I had a creaking in my saddle too. I tried eveything to stop it but nothing worked?
    Further inspection, I found that one of the two bolts that hold the saddle on the seatpost was not as tight as the other.
    After tourqueing them down the creak was gone, so make sure that the bolts are the same tourque.
    Jan 2006
    Quote Originally Posted by Wild Bill
    Thanks Wild Bill. I'll try that if the lube doesn't work.
Contest
Tour De France
