Results 1 to 7 of 7
    Jun 2008
    Shift cable tension adjustment on Colnago C59
    I started building up a used C59 mechanical frame I just bought. It has very nice cable entry points on the upper down tube and no obvious location for a tension adjustment screw. Am I missing something or are they no long accomodated?
    Thanks,
    John
    'brifter' is a lame word.
    Inline barrel adjuster.
    I work for some bike racers
    and a bunch of skateboards
    Dec 2006
    Use an in-line adjuster for only the front derailleur. There's already an adjuster built into the rear derailleur, and on the fly derailleur adjustments are hardly necessary.
    Apr 2007
    Nobody ever said progress was going to be convenient. I think getting rid of tumblers on the cable stops is just a cost cutting measure.
    Quote Originally Posted by twinkles View Post
    No. Internal routing has resulted in the lack of barrel adjusters on frame, not cutting costs.
    Apr 2007
    I could have sworn I've seen external cabled bikes without barrel adjusters @ front cable stops. Oops
    I'm sure you have, Felt being one.
  1. DS tension really high to make NDS tension acceptable. This OK?
    By bicyclemech1 in forum Wheels and Tires
    Last Post: 01-06-2014, 12:47 PM
  2. Shift cable stuck in SRAM Rival shift/brake lever
    By outhere in forum Components, Wrenching
    Last Post: 01-29-2012, 05:44 PM
  3. Convert Campy Power Shift to Ultra Shift?
    By JLane in forum Components, Wrenching
    Last Post: 01-16-2012, 07:25 AM
  4. Cable tension vs. Cable length
    By Stogaguy in forum Components, Wrenching
    Last Post: 08-11-2009, 04:23 AM
  5. Replacing shift cable & rear der adjustment
    By bent_spoke in forum Components, Wrenching
    Last Post: 09-24-2005, 04:36 AM
