Results 1 to 15 of 15
    Apr 2012
    Shimano 2300 double vs triple
    About to get a new entry level road bike and am not sure whether to go for shimano 2300 double or triple? any thoughts.....?
    Sep 2005
    Get what you like. Both work well. A triple will give you more options, a double will work just fine.
    Reputation: OldZaskar's Avatar
    Jul 2009
    Where do you live - is it very hilly?
    Are you a strong(ish) cyclist (replacing old bike, adding to mtb)?
    What type of riding do you plan to do? Mountains? Loaded with gear?
    Apr 2012
    Not very hilly where i live......only slight hills in richmond park and occasionally go to box hill, but may go abroad to do some holidays so not sure about things there.
    is there a big weight difference?
    Jul 2009
    There are coincidentally three things to consider with a triple. Only two of them matter...
    1. Yeah, there's a bit of weight penalty - not much in the grand scheme
    2. Shifting changes somewhat in that it's not just up or down. There's more room for maintenance/adjustment error, rubbing, etc. Not a huge deal.
    3. Roadies make fun of triples.
    More often than not, the decision to get a double or triple comes down to budget - the triples are very common on the lower-end bikes. So, you may want a double, but the bike in your budget has a triple...
    Unless those holidays abroad involve panniers, backpacks and mountains, you'd likely be fine with double - a compact double.
    Apr 2012
    OK, thanks.If I were to get a triple but did not like it, could I then remove a ring and keep my triple shifters?
    Feb 2008
    Quote Originally Posted by tribe3 View Post
    That will totally work.
    Jul 2009
    All you'd have to do is reset one of the two limiting screws on the front derailleur - to keep it from inadvertently dropping the chain.
    I still ride my first road bike occasionally - it had a triple. I'm down to one chain ring on that one. ;-)
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    As long as it's not the middle one.
    Jul 2009
    Oh come on, as long as he shifts really (!) fast, it'll be fine ;-)
    tlg
    tlg is offline
    May 2011
    Quote Originally Posted by OldZaskar View Post
    After I posted that, I was wondering if would possible to drop from large to small. Perhaps if the chain was really crossed and with a fast shift.
    Going up on the other hand... that's not gonna work too well!
    Apr 2012
    Ok, Thanks everyone! the bike i am looking at is a 52, 39, 30 so if i don't like triple, what gearing would you suggest i moved to?
    Jul 2009
    If you go the double route, stick with a "compact" - that'll be a 50/34. A "standard" would be a 52/39 or 53/39... typically.
    ^That^ should factor into your earlier question about ditching the small ring. If you're on the fence about a triple vs. double, that typically means you're not yet a very strong rider - unless, as we discussed earlier, you're doing a lot of loaded down mountain riding. So... buying the triple, and ditching the small ring, would leave you with the equivalent of a "standard" double - and that may be too much gear...
    Taking budget out of the equation, it's hard to go wrong with a compact - a 50/34. A 34/25 (small ring, big cog) is a very very low ratio... like barely faster than a walk kind of ratio.
    Apr 2012
    Ok, thanks for all the help, i think i am going to go for a compact now
    Reputation: looigi's Avatar
    Nov 2010
